'76 Tire Help Needed
Old Mar 20, 2013 | 08:28 PM
Cara1's Avatar
Cara1
Cruising
Default '76 Tire Help Needed
I have a '76 with incorrect tires. I have tires labeled P255/60R-15, apparently P225/70R-15 is really what is supposed to be on the car. Should I put the correct tires on for better performance and drivability?? What is the draw back to leaving the incorrect tires on?
Old Mar 20, 2013 | 08:50 PM
Ibanez540r's Avatar
Ibanez540r
The current tires are going to have "better performance and drivability". Many guys here run the 255/60/15's and it was an optional size in the later C3 years. Some cars will have a slight rub in the front wells with the steering at full lock, others don't.
It's personal preference. The 255's will provide a wider footprint for better traction, and also have a little less of a side wall for better performance. The 225's will provide that OEM look with decreased performance.
Old Mar 20, 2013 | 09:05 PM
Cara1's Avatar
Cara1
Cruising
That helps a lot, thank you!
Old Mar 20, 2013 | 09:12 PM
iokepakai's Avatar
iokepakai
My 76 with 255-60-15 and slotted wheels.
[IMG][/IMG]
Old Mar 20, 2013 | 09:18 PM
Cara1's Avatar
Cara1
Cruising
Wow! Very nice.
To '76 Tire Help Needed
