Need help troubleshooting 73 cowl induction
Old Mar 21, 2013 | 11:17 AM
gr8t73's Avatar
gr8t73
Default Need help troubleshooting 73 cowl induction
Disconnected harness connector @ headlight area & applied power everything worked as it should solenoid operates & flapper opens. Disconnected harness @ throttle position switch & applied power to harness & nothing. Not sure what to do next any help would be greatly appreciated.
Old Mar 21, 2013 | 06:10 PM
general69's Avatar
general69
Default cowl induction door
check power at the switch located at the accelerator pedal under dash
