81 passanger seat removal help please
The drivers seat bolts were easy enough to find and remove, but crawling under the car, with a flashlight I can't seem to put my aging eyes on them....even with my good glasses.
My Aim & service manual drawings make it look like the passenger side seats underside bolts are located just like the drivers seat bolts...but I couldn't find them tonight.
Do I need to have the car on a lift to get at the passenger side seat bolts or do I need to remove somthing to access these bolts? I did quite a bit of searching in this and the technical forum also and I couldn't find anyone talking about the passenger seat in paticular.
Thanks in advance for your help.
If I still can't find them I guess I'll ask one of my friends with a lift if I can swing by sometime this weekend and lift it up for better access.
I appreciat your input thought...thanks.
Good luck
The nuts on the passenger side were attached to the floor pan on the underside of the car...and the 1/2" bolts I had to remove from inside the cabin under the seat.
The front bolts were easily accessable without moving anything around, and the the rear bolts I had to slide the passenger seat forward to gain access to...then remove.
Anyway...I thought I would share what I learned today in case anyone in the future wants to remove the passenger seat in an 81.
Thanks for your input everyone.
