Started mocking up my LS3 (pics)
So I thought would share some pics and hope to get some tips along the way.
Donor car:
It's kind of sad but it's a near mint condition 2001 Firebird Formula with a t56. Right at 100k miles though. After doing a little research I found that there were only 300 or so made that year. That means nothing now but maybe it will in 30 yrs. I decided against the LS1 and bought a new LS3 block, heads and the new Holley intake. I will still use the LS1 computer though. I haven't decided if I will use the same crank from the LS1 or buy a forged crank with a 24 tooth reluctor wheel. My plan is to build simple 500 HP motor. Which is easily done with these LS3's with just a cam. I have a 2010 Camaro that is just over 600 at the wheels with a cam, victory Jr intake and a 100 shot.
My project:
1980 C3. Why a 1980??? Because ((I)) think they are awesome. I bought it a few months ago from a snake in the grass for 3500. Its a 4 speed car, sbc, small cam blah blah blah. He was against me pulling the kick panels for inspection but insisted he was in there a year ago and it was solid. No visible signs of rust on the hinge pillar or around the lower windshield. No fat gaps etc... I asked about the frame and again he said it was solid. So going against my gut feeling I bought it.
I drove it home fearing for my life once I hit highway speeds. You can see where this is going. Once I got it up on the lift the floors were gone, the frame had a 12" plate patch that looked like a blind welder did the work and worst of all when I pulled the kick panels it took every bit of strength I had to keep from going back and ripping this guys head off. I knew better before I handed over the cash but did so anyhow.
So I bought another driver with less than 200 miles on a new engine.
I thought long before I decide to continue so instead of ripping the second car apart I came across a 1980 frame that I got for a few hundred and had it powder coated. I decided to just move reconditioned or new parts over to the frame. I don't want to get to far ahead of myself and find out later something in is the wrong spot... like the motor!! So if you have been here and have any great warnings or suggestions please let me know.
I agree with you, the 80's are the best looking of the C3's.
Did you fab the exhaust at the flanges? Others have used side exhaust but had to do some serious cutting on Hookers to adapt them to the LS engines.
Rick B.
Rick B.
If you notice I put on the borgeson steering box. Im not fighting leaking cylinders.
The T56 shifter isn't going to line up with the stock console no matter where you place the engine. Unless you plan to build a custom center console you need to fab an offset for the shifter. I have the factory Hurst shifter for the T56 and it has a really small shift pattern. I don't doubt that you can handle something like this:
Rick B.
Rick B.
