Defroster Duct Install
Old Mar 26, 2013 | 05:10 PM
gr8t73's Avatar
gr8t73
Default Defroster Duct Install
I've begun re-installing the A/C ducting on my 73 & there is a 3/4" to 1" gap between the defroster duct that attaches to the dash & the diverter duct just below it. Is this as it should be & if so does anyone have a suggestion on how to seal this gap?
Old Mar 26, 2013 | 05:18 PM
F22's Avatar
F22
Be careful sealing that with anything stiff. I'd use the foam that GM used everywhere else on the A/C system. I'm only saying that, because it seemed the whole A/C - Heater duct system was designed to have some 'play' in it, because the dash relies on this for support and visa-versa.
I thought I was smart, sealing everything with aluminum tape and then screws to firm it up, but then found out, that the center console and other externalities, suddenly didn't want to fit. Does the gap seal or get smaller, when you push the diverter duct back towards the firewall? Did you seat the bottom section down too firmly? I had a 1/4 inch to 1/2 gap when I was done, but it sure took a lot of playing around with everything again and again....
Old Mar 26, 2013 | 05:48 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The cars were made this way from the factory, the gap is normal.
Enough air will pass through there to defrost.
Willcox
Old Mar 26, 2013 | 06:01 PM
gr8t73's Avatar
gr8t73
Willcox
Thanks Willcox I thought this might've the case but my memory is not what it used to be. Got to remember to take more photos.
Old Mar 26, 2013 | 08:49 PM
SIXFOOTER's Avatar
SIXFOOTER
I used aluminum duct tape to close the gap. Made no sense to me to have all that air escaping behind the dash and going nowhere so I closed it up
Old Mar 26, 2013 | 09:30 PM
0Willcox Corvette
Former Vendor
Seems to work better for sure.... But getting it apart is a bit more difficult. We see them in the shop both ways and when they come in that way we use the black duct tape.. so they leave he way they came.
To Defroster Duct Install
