Someone help
Old Mar 28, 2013 | 12:02 AM
Skip Burney's Avatar
Skip Burney
Default Someone help
I see where you can buy rear sway bars for C-3`s but neither my 72 or 73 has one. When I bought my 72 I got a ton of extra stuff with it and included were 4 new sway bars and 4 new sets of bushings but for the life of me I don`t see where a rear sway bar can bolt up. What am I missing?
Old Mar 28, 2013 | 12:09 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
holes should be there.
covered in dirt no doubt.
Old Mar 28, 2013 | 12:36 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
this shows mounting points.
the part that attaches to the trailing arm can be different.
Old Mar 28, 2013 | 03:37 AM
lance m p's Avatar
lance m p
Default I just want to say thank you..........>
I've had my ole 82 for going on 14yrs my 1st and only Vette. I've only been a member here for about 1 yr. IMHO this is the best Vette forum out there! Thanks to many very educated and helpfull people on the Vettes little quirks and differences from other....lesser vehicles! Never to old to learn something new! Thanks to all!.....and race on!
Old Mar 28, 2013 | 07:39 AM
Mooser's Avatar
Mooser
The holes for the sway-bar may not be drilled on the back of the trailing arm (reproductions tend to have them)
You need all of the linkage and brackets for the connection
If you don't have them, Wilcox gives the locations in this thread
http://forums.corvetteforum.com/c3-general/3228358-rear-trailing-arm-sway-bar.html
I believe the holes on the frame should be there on all frames.
The bar sneaks over the spare carrier, I'm pretty sure I've gotten the bar in without dropping the top part but it's easier if you do
HIH
Mooser
Old Mar 28, 2013 | 07:48 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I installed a rear bar on my wife's '79, a number of years ago. I was going to use an OE bar, but at the time, couldn't obtain any of the brackets for the trailing arms. I wound up buying the needed bar and parts from VB&P.
Old Mar 28, 2013 | 08:23 AM
toolman0114's Avatar
toolman0114
Obviously my 74 doesn't have a rear sway bar, I'd like to install one. Is there a kit available with all the brackets and bar?
Also, where exactly does it bolt? Is it on top if the rear end? Of some tubing? I can't tell from the drawing exactly where it goes
Old Mar 28, 2013 | 09:09 AM
71scgc's Avatar
71scgc
My 71's frame had no holes for the mounting of a sway bar. Never understood that.
Don't recall ever checking the new frame I installed last summer.
Carter
Old Mar 28, 2013 | 10:18 AM
leadfoot4's Avatar
leadfoot4
The bar bolts to the frame, but it might be confusing, because the mounts are to the rear of the rear axle.
VB&P can sell you everything you need, correctly sized bar, mounting brackets for the trailing arms, and all....
Old Mar 28, 2013 | 10:42 AM
Mooser's Avatar
Mooser
Tops are just under the #4 mount area
I thought all frames were drilled since the nuts are captive and had to be inside. Guess not?
Mooser
Old Mar 28, 2013 | 11:51 AM
toolman0114
So is the sway bar one long piece that goes across to both sides of the frame? Or two short bars, one on each side??
I did a search and see what appears to be one long bar with mounting rubbers, but the drawing near the top of this post shows a short bar on one side.
Old Mar 28, 2013 | 12:02 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
one bar, like the front.
the "link" to the trailing arms can be like the front bar's
best results when the front size (diameter) are matched to the rear.
say 1 1/8 in front, approx 7/16 in rear.
then spring rate and shocks can effect choice.
too much bar dia in the rear will cause over steer.
Old Mar 28, 2013 | 12:06 PM
toolman0114
Ok, how the heck do I find the VB&P website???? Cab somebody post a link to their site?
All I get is error 404 page cannot be found
Old Mar 28, 2013 | 01:39 PM
Skip Burney
NOW I got it, thanks a million guys yall are the greatest
Old Mar 28, 2013 | 02:04 PM
redman76's Avatar
redman76
St. Jude Donor '09
Same thing happened to me yesterday. Try this one: VB&P
Old Mar 28, 2013 | 02:31 PM
Skip Burney
NOW I know why I couldn`t find the holes in the frame BUBBA wrung the bolts off and ground them down flush with the frame rail so when everything was sandblasted and painted you would never see them if you didn`y know they were there. Does anyone know what size thread the holes are so I can drill and retap. I have new urethane mounts and bars in all the stuff I got so all I need to do is drill and tap 4 holes and get the brackets
Old Mar 28, 2013 | 02:45 PM
leadfoot4's Avatar
leadfoot4
I'll take a wild-azzed guess, and say 3/8-16....
To Someone help
