The old girl has the Le Mans conversion at the front.
The rubber pipes that run from the light switch through the bulkhead and under the dash are still there.
I take it I can just remove them all as they won't serve any other purpose other than take up space?
Apologies for my ignorance, whats a check valve?
When I took out the dash all I had was 2 rubber hose connected to the light switch which went on a Y piece with 2 through the bulkhead and another 2 under the the dash. They aint plugged or sealed. Do I need to block them off? If so why?
Thanks for your help so far
G in the picture below. Just block it off there and it kills all the hoses.
