Steering column issue
Old Apr 10, 2013 | 03:34 PM
coreydh9's Avatar
coreydh9
Navigator
Default Steering column issue
My 72' has a tilt/telescoping steering column. There is about .5" of vertical slop on the column. Can anyone tell me how to fix this?
Thanks,
Dale
Old Apr 10, 2013 | 03:44 PM
TurboStitchCW's Avatar
TurboStitchCW
you can check if the lower steering column mounting bracket bolts are torqued all the way down.
Old Apr 10, 2013 | 04:05 PM
TimAT's Avatar
TimAT
Tighten the 4 bolts at the lower shift bowl.
http://jimshea.corvettefaq.com/
Old Apr 11, 2013 | 10:14 AM
coreydh9's Avatar
coreydh9
Navigator
Thanks guys. I'll look at it this weekend and let you know if it's fixed.
Old Mar 25, 2014 | 10:00 PM
coreydh9's Avatar
coreydh9
Navigator
Seems to be worn out at the hinge, guess I'll have to replace it.
Old Mar 25, 2014 | 10:10 PM
Jim Shea's Avatar
Jim Shea
Go to this thread in the Tech/Performance Section
http://forums.corvetteforum.com/c3-t...n-rebuild.html
Jim
To Steering column issue
