Broken steering column parts need help
Old Apr 10, 2013 | 03:45 PM
Kuhndar's Avatar
Kuhndar
Default Broken steering column parts need help
I have a tilt telescope column on my car and have a broken ignition switch rod or so called interlock part inside of it, I can't seem to find this part anywhere, anyone have any ideas maybe I'm calling it the wrong thing but I can't find one. Ift the part that connects to the ignition switch activation gear in the column.
Old Apr 10, 2013 | 03:47 PM
TurboStitchCW's Avatar
TurboStitchCW
I thin you may be referring to the ignition lock cylinder.
Can you turn the ignition without the key?
Old Apr 10, 2013 | 04:02 PM
Kuhndar's Avatar
Kuhndar
No it's the rod that goes down after the lock cylinder, it's what triggers the key to move the ignition switch
Old Apr 10, 2013 | 04:04 PM
TimAT's Avatar
TimAT
Get a copy of Jim Shea's steering papers at
http://jimshea.corvettefaq.com/
That will give you the correct names for all the parts.
I suspect (SWAG) the part broken is the rack (common) and those parts are still available from GM.
Old Apr 10, 2013 | 04:13 PM
TurboStitchCW
ignition switch actuator gear (swag) is what I found on google search:
Old Apr 10, 2013 | 04:31 PM
Kuhndar's Avatar
Kuhndar
That would be it anyone have a good place to get one from?
Old Apr 10, 2013 | 04:34 PM
TurboStitchCW
was doing some research and found a thread by Jim Shea and he showed this pic...it shows a good part number that you could probably get at your local Oreilly's:
Old Apr 10, 2013 | 09:34 PM
Mark G's Avatar
Mark G
Doesn't Ecklers have them?
Old Apr 10, 2013 | 09:58 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
Just about every auto parts store carries those "HELP" parts. Call around locally.
To Broken steering column parts need help
