Spider web cracking, at what point......
Old Apr 10, 2013 | 10:30 PM
Reno31's Avatar
Reno31
Cruising
Default Spider web cracking, at what point......
So lots of corvettes I've seen have some amount of spider web cracking from an inch or two in just a couple places, to large amounts of space in multiple areas.
My question is does it always spread like wildfire, and at what point should you do something about it? Does it ever really compromise the integrity of the fiberglass strength in that area or is it strictly paint?
Basically if you purchased a car with a couple small places on it, are you going to need a full paint job? 6months.......6years.....???
Old Apr 10, 2013 | 10:36 PM
qwank's Avatar
qwank
I have a spider web crack on my right front fender since I bought the car. it doesn't appear to have gotten any bigger in the 3 years I've owned it.
Old Apr 11, 2013 | 12:36 AM
stinger12's Avatar
stinger12
It is in the fiberglass, which then transferred to the paint . It is usually just cosmetic, and all that is needed is one layer of fiberglass on top of the spider crack. If there are lots of cracks in the same place you are better off grinding the whole surface down and glassing the whole area with one layer. This also applies to gel coat cracks. New panels should be checked for cracks using wash and wipe and a blow gun before any sanding is even done...they are easier to detect this way.
It is usually caused by rocks being thrown up by the tires into the bottom of the fiberglass. I just did a bunch of repair work on an 88 Chevy at work, which is a common problem from the factory. Ground the entire topside down and laid one layer of glass down. We then had the undersides of the box sides bedlined to prevent any future rocks from causing any damage. If they are not glasses and just painted over again, they will show up in a new paint job fairly quickly.
Old Apr 11, 2013 | 08:33 AM
74Ken's Avatar
74Ken
When I had my 79 Firebird painted a long time ago by a friends fathers shop. He told me they added a 'flex agent' to the paint so that it wouldn't spider crack on the rubber bumpers. After I picked up the car, he showed me the remainder of the paint in the can...it had turned to pretty much jello. I never had a spider crack after that until the day I sold it.
Does anyone know if they still have this 'flex agent' out there? If they do, I would use it on my 74 if/when I decide to paint it.
Ken
Old Apr 11, 2013 | 08:54 AM
stinger12's Avatar
stinger12
Ken
Flex agent is only to used on flexible parts for a reason. They are flexible and if you don't add it it cracks immediately. It will not prevent against stone cracks.
Fiberglass is not flexible.
Old Apr 11, 2013 | 09:12 AM
74Ken's Avatar
74Ken
Is there are real name for the flex agent? or is that what it is called?
Old Apr 11, 2013 | 09:14 AM
71scgc's Avatar
71scgc
I have a vintage Gordon&Smith Fibreflex skateboard that disagrees with you, vehemently.
Old Apr 11, 2013 | 08:06 PM
stinger12's Avatar
stinger12
That's great! Go ahead and use it then. I'm just a licensed autobody painter.
Old Apr 11, 2013 | 08:07 PM
Mark G's Avatar
Mark G
I agree, usually people see cracked paint and translate that into the fiberglass being cracked. Usually it is the 8 layers of paint on top of the fiberglass that fail due to expansion/contraction of the fiberglass from the heat of the sun, cold and what-not. Old paint jobs that use lacquer or enamel are prone to cracking due to age no matter what substrate they were painted over. They were 'hard' paints that didn't have a lot of flex properties. My old Caprice's original paint was severely cracked after 10 years way back in the 90's, and that was original paint over steel.
But it if WERE cracks in the fiberglass, then you need to take care of it during a paint job. Not too difficult, just takes a little more time. Hope this helps.
Old Apr 12, 2013 | 08:05 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What are you looking at? The traditional definition of spider webbing is a condition of old lacquer paint, not any type of body or fiberglass damage.
Old Apr 12, 2013 | 09:44 AM
Reno31's Avatar
Reno31
Cruising
A car I have looked at has a couple places right on the nose of the front bumper about 2 inches deep into the bumper and 4 inches wide and a spot the size of a quarter under the door handle on one of the doors. I can live with the issues, just don't want them to become significantly worse in a short period of time.
To Spider web cracking, at what point......
