Question,...pictures...help?
Old Apr 12, 2013 | 02:28 PM
Cattiva73's Avatar
Cattiva73
Default Question,...pictures...help?
Hello guys,
after I tracked down one of previous owners of my '73 Corvette I had him send me the last pieces/parts that came with the car.
One is the AC unit and the other part...??.I have no idea
Also when I received the AC compressor, there was a leak in the box that looks like refrigerant oil!!! Is it a bad sign that the unit is not good?
The PO bougth the unit at a used parts store but never installed it.. ..oil is coming out of one of the attachments holes..?
here's some pictures.
Thanks I appreciate your input.
what is this??
Old Apr 12, 2013 | 02:42 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Compressor and valve in receiver (VIR). Do you have the assembly instruction manual showing how they install. The oil leak does not necessarily indicate the compressor is bad; only that plugs were not installed before it was shipped.
Old Apr 12, 2013 | 09:09 PM
Cattiva73's Avatar
Cattiva73
Thank you Mike.
I do not have instruction manual..Im not going to install it myself anyway.
Old Apr 12, 2013 | 10:02 PM
TimAT's Avatar
TimAT
You should rebuild or replace the VIR. It's open to the atmosphere and the dessicant will be full of moisture- not the best thing to make cold air with.
To Question,...pictures...help?
