Manual Trans Access Panel
Glad I did it, as the reverse linkage bolt came loose for a second time and wrench and hand access borders on the sadistic.
The best part was adjusting the linkages! No hand torture, total breeze and did it in under an hour, without going under the car. Only required assistance to push the shifter hard against the limit in reverse, because the 0.644 gauge has the tiniest amount of room in the reverse neutral notch alongside the shifter. Only then and while.pushing the gauge inward and wiggling the rod, will you get 'The Lock'. Got the panel and buttoned it up in five minutes.
Ok, still happy I did this. The shifting is so nice and it was so easy to adjust while there. You can see the speednuts. I scribed the plate from the back, with a 90 degree scribe, to locate the holes in the back of the plate:
Here's the plate: 20 gauge steel and the markings are for forming the plate to the transmission tunnel.
Then, while I was at it, I had drilled a hole in the gauge, so I wouldn't mistake it for a piece of scrap metal. After trying to fit hand, down in shifter hole, I said to myself, 'Screw That!' and I made it into this:
Now see how easy it is, to put it down the shifter hole AND push it into the slot for neutral. Much, much easier! I could wiggle the shifter with one hand and work the gauge into the slot with the other. As mentioned, the only help needed, was for the reverse slot and my partner, held the shifter hard against the limit, so that the gauge could slot into the reverse position next to it. Found the sweet spot lock and spun the nuts!
Remember, at the factory they dropped the body on top of the chassis, with the engine and transmission, already in it (and I imagine the shifter too!).
It seems like a fair amount of work, true but it was waa-aay easier doing this, than attempting to adjust it again. If that Blue Moon comes up, all I have to do is pull the console and carpet and the plate is right there, versus the alternate.
