Hello I have a C3 with badly worn carpet in front. Want to get entire front set and put some sort of heat sheild between carpet back and floor. Where and what to get is my problem and any extras i will need to complete the job corectly. thanks for your help guys.
I would buy the full set.. and I'd make sure it's ACC brand.. When you go with a 1/2 set the odds of the front matching the rear are slim... and the cost is not that much different.
You'll probably need the console side panels too.. they are usually in bad shape.
