Engine block vin
Old Apr 15, 2013 | 10:01 PM
Paddyo's Avatar
Paddyo
7th Gear
Default Engine block vin
I am having a hard time trying to find this engine vin on line. I bought it as a mid 70s Corvette engine. But I can't seem to find out any info on it. Any help would be greatly appreciated. Casting number 3970010. Vin # 141495472. K07 10 CMR. Thanks guys!
Old Apr 15, 2013 | 10:12 PM
John 65's Avatar
John 65
Code cmr is a 78 220hp (L82) in a stick car.
Old Apr 15, 2013 | 10:16 PM
Tom73's Avatar
Tom73
CMR suffix was used three times, only one was a vette.
1974 in the A body cars
1978 in the vette/ Z28 - L82
1980 in full size as a 305
That VIN just does not look like a Vette's VIN. Also believe that "K" should be a "V" for the flint plant where the vette engines were assembled.
Tom...
Old Apr 15, 2013 | 10:18 PM
Paddyo's Avatar
Paddyo
7th Gear
I found the same thing with the CMR code, so can you tell from the vin?
Old Apr 15, 2013 | 10:41 PM
Mike Ward's Avatar
Mike Ward
The K in the engine code K0710CMR means that the engine was assembled at the McKinnon Industries engine plant in St. Catherines Ontario Canada on July 10.
No C3 Corvette engines were assembled there.
Casting 3970010 was not used for 305 cu.in engines.
The VIN derivative format doesn't look familiar, but with the 4 as the second character, I'm guessing it's from a '74 A-body car, possibly built in the St. Therese Quebec GM plant.
Old Apr 16, 2013 | 08:32 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Mike Ward
The K in the engine code K0710CMR means that the engine was assembled at the McKinnon Industries engine plant in St. Catherines Ontario Canada on July 10...No C3 Corvette engines were assembled there...The VIN derivative format doesn't look familiar, but with the 4 as the second character, I'm guessing it's from a '74 A-body car, possibly built in the St. Therese Quebec GM plant.
To Engine block vin
