I'm trying to decide if it's worth the $1,000+ difference for drilled and slotted rotor style brakes vs. conventional Corvette OEM rotors. What do you think?
I agree on the "appearance" issue. That's probably why I was even thinking about putting them on the car. However, some people say the slotted rotors will decrease stopping distance. Is this true?
If there's somebody that's found a way to actually sell rotors at a $1000 more a set just because they have 'slots and holes', I'm in the wrong business. My hat is off to him.
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
The slots/holes are there to let gas escape from repeated, hard-braking as would be experienced on a road course. While it is true that you will loose some braking surface due to these machining marks, personally I don't think you will see any measurable decrease in stopping distance. Your pads should be where you focus your attention if braking distance is of concern or that is my opinion anyway.
From: Graceland in a Not Correctly Restored Stingray
There's definitely a time and place where slotted rotors are a good call (see post #6), but IMHO unless you plan on doing some tracking they're difficult to justify. Then again, if they're strictly for bling / bragging rights, then by all means you should definitely waste your money on them.
Get a quality brake pad like the Carbotech 1521 pad. If you are interested I will be happy to help you.
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
...some people say the slotted rotors will decrease stopping distance. Is this true?
If you can lock up the tires now, then no. And even if you can't lock the tires, a rotor will not make a difference unless yours are glazed. You'd want to look at a more appropriate pad before throwing money down a bling rotor rat hole.
Unless you're a heavily involved in road course racing, and even if you are, good drilled/slotted discs are very expensive. Lots of them are "strictly for 'bling factor'" and are prone to cracking between the drilled holds. Many weekend warriors I know are using the stock rotors with race pads, of course.
If you're serious and want more braking, consider upgrading to C5 calipers and rotors, front and back. It will be far cheaper, and more effective than drilled/slotted cheapies.
FWIW,
P.
Have you ever run the car so hard that you gassed your pads? Probably not.
I gassed my pads once at Bridgehampton many years ago. Pad material has improved so much that even in time trials, I never have issues. Get good pads, make sure the calipers are not leaking (change brake fluid) and check for excessive run-out in the rotors and if you really need it, add venting to the brakes (more for tracked cars). I see no reason to need special rotors if the basics are covered.
I used to drive the country roads daily with my old daily driver. The roads had lots of turns and a 55mph speed limit. Many days I would feel my brakes get soft on me (one time they were smoking). I put drilled and slotted rotors on, and never had those issues again. Now I don't drive those country roads anymore, so I don't have the need for drilled and slotted rotors anymore.
FWIW,
P.
But won't stop the car any faster..................
