power steering mounting
Old Apr 17, 2013 | 10:12 PM
crashdog172's Avatar
crashdog172
Default power steering mounting
The power steering pump on my '75 is under the alt. in a position where you can't even get the cap off to check the fluid.I know this can't be normal. somebody put the wrong brackets on or what?
Old Apr 18, 2013 | 02:14 AM
aussiejohn's Avatar
aussiejohn
Default Perfectly normal.
G'day,
That is perfectly normal for these cars, your best shot is to find a shorter belt or get a Summit catalogue and look for a billet aluminum alternator bracket. That's what I did to my '74 coupe, but still had to grind a small amount off the bracket to get the filler cap off.
Regards from Down Under.
aussiejohn
Old Apr 18, 2013 | 10:51 PM
crashdog172
Originally Posted by aussiejohn
G'day,
aussiejohn
Thanks aussiejohn
Thats kind of what I was thinking.I am going to try a shorter belt first although doesn't look like much adjustment there.
To power steering mounting
