Hello Guys,
Is there any way to identify spec of cylinder heads with opening parts? I want to order long tube headers for my C3 1972 (Original 350 small block), but I am not sure to select which type Oval or D-port shape.
Thanks for all clarifications, just one more thing, I'm getting difficulty in selecting a long tube headers, which type/size would be the best for this engine? I prefer Hooker super competition, but When I searched I found some bad feedback. Please advise. My corvette is 1972, auto transmission (hydra-matic), power steering and AC.
I found 8970010 on the block. Do you know what the head valves sizes are? The picture is clear, is this is the oval shape?
The casting number is actually 3970010 which is the type used in virtually every GM product during the 70s. It has nothing to do with the heads or valve diameter. Given that your engine is the base 200 HP, valve sizes are 1.94 intake and 1.50 exhaust.
Very honestly Mohamed, with the base engine/auto combo you've got, I wouldn't bother. You'll get maybe 99% of the power with stock manifolds and a 2 1/2" free flowing exhaust system. At a much cheaper cost.
Power isn't my concern, I've been told that a long tube headers will reduce heat around the engine and will give good sound with the Magnaflow that I already put. Is this correct?
Thank you Mike,
For the block, how can I determine if it is 2 or 4 bolts? I want to remove the engine for overhaul, so by the way how can I improve it?
I disagree with the sentiment on headers vs stock exhaust manifolds.
On my 78 L-48, there was both a noticeable "butt dyno" change, as well as a 3/4 second gain in 0-60 time going from the stock manifolds to 1 5/8" long tube headers.
Pulling the pan will tell you whether it's 2 or 4 bolt. Since it's the 200hp motor, it's likely just a 2 bolt. It can be converted to 4 bolt by the machine shop. I'm more fond of building second motors if the original is still in one piece.
My '72 L48 has 2 bolt main caps. My experience is they are plenty strong except in the highest of HP configurations.
I've only seen one cap failure and it was in a boat. When disassembled the three middle caps were broken (it still ran) but boats, unlike car engines, spend a long time at WOT.
