Thoughts on this '75 383 Stroker?
I'm planning on checking this car out this weekend:
http://sfbay.craigslist.org/eby/cto/3747930645.html
Can I get some feedback/opinions on it? Any help is greatly appreciated!
Personally I'd take the included numbers matching 165 HP POS to a recycler so that it never sees the light of day again.
Hopefully the frame and birdcage is nice. Good that the entire A/C system is included but I'd be knocking off money for the time it takes me to reinstall it.
Lastly, what are the emissions testing requirements in your area? You will most likely run into problems if it needs to be tested.
Personally, if it all checks out and looks as nice as it does in the pics, I could see dropping $10K.
http://sfbay.craigslist.org/sby/cto/3741632828.html
oh yeah, and in California - the 75 you don't have to smog, the 77 you do
but they both look nice and unmolested
so when you going to buy it and put a man-pedal in it?
Edit: I just noticed that the seller says it has a mild Comp Cam. Depending on what his definition of mild is, that
car may be better off than mine. Mine is also a Comp Cam, but I wouldn't call it mild even for a 383. Mine is this one: http://www.compcams.com/v002/Pages/397/XR282HR-10.aspx
Personally, I would have preferred this one: http://www.compcams.com/v002/Pages/396/XR276HR-10.aspx
or even this one: http://www.compcams.com/v002/Pages/395/XR270HR-10.aspx
for better vacuum and economy with probably little sacrifice in power/torque.
Price is a bit high, but that shouldnt be a problem. Looks like a great driver that you can pile on the miles without worry. Look at it closely.
However (and not to be a "Debby Downer," but just trying help you spot potential problems): is there an alignment issue with the Right Headlight Bucket? The panel gaps between that one and the hood surround look different (bigger?) than the Left side, to me.
But it could just be the beer....
Possible negotiation tactic (as was already suggested): consider getting a WORST CASE phone quote from a good shop, to reinstall the A/C. (I'd also ask WHY it wasn't put back on--I'm always suspicious that it was dead, if A/C is removed. I'm told that metal particles from a failed compressor are difficult and expensive to contend with, as they can be all through the system--and I believe they can potentially ruin a new compressor).
Good luck.
Dumb Question: why are the fiberglass floorboards preferable? Are they quieter? Cooler (temp.-wise)? Lack of rust? I would have thought metal was preferable, from a safety standpoint.
LOL!
Well, it's game day, I've printed out list of potential problems to check and also the standard checklists. I'll report back later on today
White car is way overpriced IMO, on the late 70ties corvettes having a stock car is not a bargain point, since stock = disappointing 160hp and minivans raping you at the stop light.... even the description is garbage! who starts describing maintenance on a 35yo car with spark plugs, hoses and oil change?
The Good:
Car is in surprisingly good shape, looks to have been well taken care of
Jacked the car up and checked for excessive rear wheel bearing slop...nothing out of the ordinary
Paint is excellent, emblems, door handles, taillights etc. were all removed rather than taped
Engine sounds great, had receipts for all the work done
New Magnaflow exhaust
New tires
Rear calipers replaced with SS sleeved ones
New radiator(not sure if copper or alum, it was painted)
PO says trans was rebuilt, but current owner has no proof
Interior needs a scrubdown, but is in otherwise good shape
The Bad:
Front end has never been apart
Power steering control valve has a small leak and is encased in crud
Rear wheel bearings have never been serviced
Air conditioning has been removed
Cooling issues...radiator needs to be sealed, plus owner says he replaced the coolant sensor and car runs cool....been down this road already and I know the gauge cannot be reading accurately...should be checked
Unsure about trans
Seat covers need to be replaced
Still has original front calipers
I suggested offering the man $9K but would not give more than ten, but before that let's hear what the Forum says
