PO2 restoration thread
Old Apr 20, 2013 | 04:19 PM
Vicky Vette's Avatar
Vicky Vette
Default PO2 restoration thread
I recently picked up a fairly decent set of PO2 hubcaps on eBay for $280. The center caps are good and will clean up with a little polishing.
The first step is to disassemble them and polish the outer rib section. This will be done from both the left and right of the buffer in order to fully hit both sides of the raised ribs. I will also buff everything else at this time including the scratches in the black paint. Compound will be gray heavy cut, green medium cut, white light cut, and pink finish cut followed by hand rubbed Stainless polishing cream. After polish I will clean them with 3M grease and wax remover. All the black areas will get a light scuffing with 3000 grit trizact, followed by more wax and grease remover I had 300ea. 1/8" wide x 2" long die cut vinyl decals made with an 1/8" radius on the end. These will be used to mask the raised spokes. The rest will be masked with green 1/4" masking tape. Before paint they will get a light cleaning with Kleen Strip Final Wipe and a tack rag. I will use VHT self etching gloss black epoxy paint.
More details and pictures will follow as the project continues.
Bob
Old Apr 20, 2013 | 04:45 PM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
Bob, I appreciate you starting this thread and letting us see how the PO2 restoration goes. As mentioned before I will be doing the same thing within a few months....So I will be sure to make a list as this progresses.....
And where did you get the vinly decals made, or since you had so many made, and may have extra's, would you sell any?
BTW that is a great idea for masking off those areas........Tom
Old Apr 20, 2013 | 05:10 PM
Vicky Vette
Tom,
My neighbor owns a sign shop and has a computerized cutter for these.
I will ask him if he is willing to sell sets. It takes 288 to mask a set of 4 caps and I figured a few extra for the ones I will most likely screw up. He also made these for my truck:
Bob
Old Apr 20, 2013 | 05:19 PM
Vicky Vette
At 2" long the decals extend slightly past the original mask, but that area is covered by the outer cap. This leaves enough room to pick up the decal with a razor blade without damaging anything.
Bob
Old Apr 21, 2013 | 07:28 AM
Blue73Shark's Avatar
Blue73Shark
Nice work Bob. Looking forward to more pics and write up. I have a set that I would like to do the same.
Fran
Old Apr 21, 2013 | 07:58 AM
Ret.Horsecop13's Avatar
Ret.Horsecop13
St. Jude Donor '11-'12-'13-'14
Old Apr 21, 2013 | 10:00 AM
74 LS4-454's Avatar
74 LS4-454
[QUOTE=Vicky Vette;1583692637]Tom,
Bob
Bob, get back to us on that for sure, as there may be other members interested in the decals, they seem like a real time saver, which will help the project in getting that perfect finish. I for one would purchase a set...... Tom
Old Apr 21, 2013 | 05:56 PM
Vicky Vette
The polishing is not meeting my expectations. I will start the long and tedious task of wet sanding the outer rim. Starting with 320 and working up to 3000 grit trizact.
Old Apr 21, 2013 | 06:28 PM
Vicky Vette
Using a wooden table and drift to re-aling a slight curb dent.
Old May 2, 2013 | 08:52 PM
74 LS4-454's Avatar
74 LS4-454
Hello Bob, any updates?????? Tom
To PO2 restoration thread
