What is this?
Old Apr 23, 2013 | 05:24 PM
bustinthings's Avatar
bustinthings
Navigator
Default What is this?
Can someone tell me what this part is? And can i live without it? My new performer 2101 does not seem to support this peice. Thanks.
2013-04-22_17-07-36_490 | Flickr - Photo Sharing!
Steve
Old Apr 23, 2013 | 05:27 PM
David Mc's Avatar
David Mc
The EGR or the hot air choke?
Old Apr 23, 2013 | 05:29 PM
Super6's Avatar
Super6
It's the actuator of the Exhaust Gas Recirculation (EGR) valve, a polution-control device that recirculates exhaust gas back into the intake. You don't want one, unless your state requires it, as the EGR set-up hurts performance.
Old Apr 23, 2013 | 05:30 PM
Brcmpbl's Avatar
Brcmpbl
That sir is the Exhaust Gas Recirculation (EGR) valve. You may need it to pass smog tests, depending on where you live and what the associated laws are. As a general answer though, no you don't need it for the car to run...it is an emissions control device. You'll have to also plug / eliminate the vacuum fitting that controls it on the other end of the tube.
Old Apr 23, 2013 | 05:31 PM
bustinthings
Navigator
You guys rock so much, Thanks!
Old Jun 3, 2013 | 09:15 PM
bustinthings
Navigator
OK, I have another part to identify, and it's purpose.
2013-06-03_20-08-14_203 | Flickr - Photo Sharing!
Thanks,
Steve
Old Jun 3, 2013 | 09:25 PM
qwank's Avatar
qwank
more emissions stuff. what year is your car, what are you doing to it, and does it need to pass a smog test ?
Old Jun 3, 2013 | 09:31 PM
bustinthings
Navigator
It's a 1978 with the L-48. I am finishing up replacing the carb, intake manifold, and radiator. Also trying to swap out the mechanical fan for an electric fan and i need a place for the temp sensor.
I know one hose goes to the carb, where does the other one go?
PS this forum Rocks! 10 minute response time, or less!
Thanks,
Steve
Old Jun 4, 2013 | 09:47 AM
gcusmano74's Avatar
gcusmano74
The dohicky on top of the 'stat is a thermal vacuum switch. Some emission devices only work when the car is fully warm, so the switch is closed until the 'stat opens. Then it allows the vacuum signal to go to the device. Right now, it's an open vacuum leak. Cap it off, until you figure what it is supposed to control.
Old Jun 4, 2013 | 10:32 AM
SIXFOOTER's Avatar
SIXFOOTER
I think that TVS is supposed to run the Evap canister.
Old Jun 5, 2013 | 09:02 AM
bustinthings
Navigator
So in everyones professional opinion, do I need it? Can I replace it with a temp switch for the electrical fan?
Also, just for fun, why is there an electrical connection on the bottom of it?
Thanks,
Steve
Old Jun 5, 2013 | 04:05 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by bustinthings
...10 minute response time, or less!...
FWIW: if you have the 78 assembly instruction manual (AIM) you can look all this up on your own for an even quicker response time. If you do not have an owner's manual, order a reprint when you order the AIM.
To What is this?
