blown fuse I think???
Old Apr 30, 2013 | 05:59 PM
RockHeadss's Avatar
RockHeadss
St. Jude Donor '10
Default blown fuse I think???
I have a question the passenger window dose not work and the AC is not working ,But It did work at one time .
I used the cigarette lighter as a cell phone charger. After that the window and the AC stop working. I check the fuse and it seems to be good. What else should I look for?
Old Apr 30, 2013 | 06:12 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Replace the fuse with a known good one. I've seen fuses which looked fine to the naked eye in the fuse block, but were bad when you got them out in the light of day.
Old Apr 30, 2013 | 06:45 PM
Blame's Avatar
Blame
Bad fuse can look like a good fuse. But if a fuse is older then 10 years best replace them all. And be done with them all.
Old Apr 30, 2013 | 06:47 PM
RockHeadss's Avatar
RockHeadss
St. Jude Donor '10
I did replace all of the 15 and 25 amp Fuse's with no luck . Did I look at the right ones or not . The cut sheet that I have is not the greatest . The( O.E.M. Manual )
Old May 1, 2013 | 09:06 AM
Big Block Dave's Avatar
Big Block Dave
Silly question, but does your driver side window work? You only mentioned the pass side. If the driver window works, it cant be the fuses, or relays, but has to be the window switch or the motor.
If I recall correctly, the relay is under the console, pretty much right under the radio, and the circuit breaker should be in the engine bay, pretty on the firewall right infront of driver. It will look like this:
http://www.ecklerscorvette.com/corve...1968-1974.html
or this
http://www.ecklerscorvette.com/corve...1979-1982.html
Use a test light to see if power is going in and out of the circuit breaker, and in and out of the relay. Again, if the problem isnt there its at the switches or the motor in the door
To blown fuse I think???
