Starter Code Help
Old May 1, 2013 | 04:09 PM
Tevroc98's Avatar
Tevroc98
Default Starter Code Help
I have a 1108430 starter. Code on it is 4J17 2
I assume its a 1974 Oct 17?? The last digit is a "2 " but spaced away from the others. Does that mean anything? Is the starter a small block or big block starter? Thanks for any info you could pass along.
Old May 1, 2013 | 04:43 PM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
The 1108430 first shows up in 1970 -1972 for all 350 engines with Turbo- Hydramatic
Old May 1, 2013 | 04:46 PM
Mike Ward's Avatar
Mike Ward
Also the correct number for '73/'74 SBC with auto trans.
Old May 1, 2013 | 04:52 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Quasi-educated guess: the 2 could be Second Shift.
Old May 1, 2013 | 09:52 PM
Ironcross's Avatar
Ironcross
Should be a staggered bolt aluminum nose starter and will fit from 70 and up both big block and small block., standard and auto`s........it will fit thousands, cars, trucks and whatever
Old May 1, 2013 | 09:55 PM
gbvette62's Avatar
gbvette62
I'm pretty sure, that the "2" would be 2nd shift.
To Starter Code Help
