steering issue...
Old May 5, 2013 | 06:17 AM
Fredscott's Avatar
Fredscott
Default steering issue...
My 82 has a slight quirk in the steering. I seem to be in a constant state of correction when driving....the steering feels kinda "sticky".
All bushings on the front end have been replaced with eurethane, shocks and springs are good, wheel bearings are good, new tires and a front end alignment 2 weeks ago. The only things left are an adjustment to the steering box (not sure how to do) and replacing the steering damper.
could the steering damper cause "sticking"? Anybody have any thoughts on how to check for proper adjustment on the steering box?
Fred
Old May 5, 2013 | 09:58 AM
Manix's Avatar
Manix
I did the on the fly steering adjustment twice on my 79 after new tires and shocks, did wonders, before it was scary to drive at speed. FYI...there was no grease in my box, filled it with Mobile syn.
Old May 6, 2013 | 10:06 AM
TWINRAY's Avatar
TWINRAY
Ball joints or Idler arm torqued too tight
Old May 6, 2013 | 10:16 AM
Stingray-Jer's Avatar
Stingray-Jer
On the fly adjustment?? What did you do. I know what you mean about being scary to drive at speed.
Old May 6, 2013 | 10:21 AM
F22's Avatar
F22
The steering box adjustment is pretty easy. Look on top of the steering box and you'll see a large nut, with a slotted screw in the center. Loosen the nut and tighten the slotted screw and then back off a 1/4 turn and see how it feels after that. This takes up the lash in the gears inside.
Old May 6, 2013 | 05:16 PM
Manix's Avatar
Manix
Here's what I did, I read it here.
Got the wheels as strait as I could by eye.
Loosened the keeper nut on the box and turned the lash screw until I felt some resistance, about a quarter turn and tightened the keeper nut. Helped right away, after a week I did it again, total was a little under halfway around. It looked like mine had never been moved, the car had 23k miles when I got it. Filled the box 3/4 full with grease.
This was one of the post I liked, there are many.
http://forums.corvetteforum.com/c3-t...ent-works.html
Hope this helps.
Old May 6, 2013 | 09:41 PM
Stingray-Jer
Hope this helps.
Thank you very much. I have all new suspension and am having the steering column rebuilt.
I was thinking that this might be the time to change over to a Borgeson Box because this thing scares #$@& out of me at speed.
Old May 6, 2013 | 10:02 PM
aussiejohn's Avatar
aussiejohn
Default Smartest move you'll ever make.
Well, with your car, anyway. I put the Borgeson box in my '74 coupe and it made a huge difference to the way it drives. Basically, it brings the car's steering into the 21st century because it uses a 21st century steering box. You even get to use your original Pitman arm and all of the other steering components deigned by Zora and GM.
Regards from Down Under.
aussiejohn
Old May 6, 2013 | 10:05 PM
Stingray-Jer
aussiejohn
Thanks Aussiejohn. I have not ruled it out. What was the biggest change you noticed?
Old May 7, 2013 | 08:28 PM
aussiejohn's Avatar
aussiejohn
Default Biggest change?
SJ,
I drive a 2010 Holden Cruze, just a RHD Chev Cruze, and am used to the very precise steering it has. Of course it's rack and pinion, but the overall ease, precision and minimal turns lock to lock make it fun to drive. The Borgeson box puts that feeling into my 39 year old Corvette coupe and apart from being LHD, gives a similar steering feel to the Cruze.
In case I forget the improvement, I also have a '74 vert with factory power assisted steering and I can readily feel the difference between the steering in the two Vettes. Also, there are no PS fluid leaks, and the hoses are tucked up above the chassis and are easy to check on compared to the factory set up.
Compared to other types of steering kits available, the Borgeson kit was a simple bolt-in that required no alteration to exhaust, clutch linkage or oil pan etc. With a hoist and simple hand tools, plus a Pitman arm puller, a competent mechanic could do the swap in an hour or so.
Hope this helps.
aussiejohn
Old May 7, 2013 | 09:07 PM
Stingray-Jer
SJ,
Hope this helps.
aussiejohn
Thank you Sir
To steering issue...
