That spare tire
Old May 8, 2013 | 04:24 PM
  #41
jdbuddy's Avatar
jdbuddy
Has anyone found a donut that will fit - save weight and have a spare?
Old May 8, 2013 | 07:48 PM
  #42
Doug Kraft's Avatar
Doug Kraft
97 Camaro will fit. 16" space saver.
Old May 8, 2013 | 08:07 PM
  #43
calwldlife's Avatar
calwldlife
St. Jude Donor '22
81 came with the 50mph donut.
steel rim, I put a full size on.
Old May 9, 2013 | 08:46 AM
  #44
KevinG's Avatar
KevinG
Removing tire from carrier is fine. However I wouldn't recommend removing the tire carrier. I had mine off for about a year after i was working on other things. For some reason, the back end was just not looking right - like there was too much space going on and not to mention seeing the driveshafts from the rear of the car. Once the tire carrier was put on, much happier and seems to "complete" the look of the back end.
Old May 9, 2013 | 09:12 AM
  #45
Blame's Avatar
Blame
On sunday i plan on building something to house tools and other got have items.
Old May 9, 2013 | 09:18 AM
  #46
fleming23's Avatar
fleming23
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Any of you folks who "built" something to put in the carrier, can you post any photos of what you constructed?
This is a pretty good idea but everyone will have their own unique ideas that could benefit the whole if shared. I never even thought to store anything in the carrier until reading this thread.
Old May 9, 2013 | 09:29 AM
  #47
billcarson's Avatar
billcarson
plus have some kind of locking device.you might want to consider keeping this in the carrier as it might save you from the flatbed,and the resulting damage.ARB 10000010 Orange Speedy Seal Tire Repair Kit.i just got mine and it is a proffesional tool set.
Old May 9, 2013 | 10:06 AM
  #48
SuperBuickGuy's Avatar
SuperBuickGuy
I removed the spare tire, and moved the gas tank down to help with the CG.
(oh yeah, I also built a stainless tank)
the spare is not a crash protection... the huge steel bar behind the frame is crash protection (ish)
Old May 9, 2013 | 10:15 AM
  #49
TWINRAY's Avatar
TWINRAY
Originally Posted by Konkol1
So, does that mean to say you know positively that the wider P255's will fit in the spare tire compartment? That's not what i'm getting from your reply. I am probably going to have to try it for myself to make sure. If the P255's I'm running won't fit in the spare compartment, there is no reason to even have a spare.
Ok, since someone brought this up - I have a 40 year old 7.75 X 15 spare in the carrier, it's prior to the letter series tires and was there in 1973 when I bought the car. I'm now running 225x70x15's and just found out last year that they won't fit in the tub. I need to replace the 225's (and probably that 40 yo spare) and was thinking of getting the largest size tire (getting 5 tires) that will fit in the tub - I wonder if 215's would fit since 205's are really too small. What do you do on the road when you can't fit your flat in the tub??
Old May 9, 2013 | 10:19 AM
  #50
Blame's Avatar
Blame
Ill take pic of my finish project. But i plan to fit a electric air pump, tire repair kit, and a set of tools i may need with oils and a small can or bottle of gas.
Old May 9, 2013 | 10:25 AM
  #51
Blame's Avatar
Blame
Originally Posted by TWINRAY
Ok, since someone brought this up - I have a 40 year old spare in the carrier, it's prior to the letter series tires and was there in 1973 when I bought the car. I'm now running 225x70x15's and just found out last year that they won't fit in the tub. I need to replace the 225's (and probably that 40 yo spare) and was thinking of getting the largest size tire (getting 5 tires) that will fit in the tub - I wonder if 215's would fit since 205's are really too small. What do you do on the road when you can't fit your flat in the tub??
If the spare tire is the same as the other 4 why not place it in the back of the vette? If its donut spare the keep it in the tub and when replacing a flat put the flat in the back.
I may do this once i buy new rims. Store the 5th rim in the back with something covering the tire part up.
Old May 9, 2013 | 10:29 AM
  #52
bashcraft's Avatar
bashcraft
225x70x15's fit in my carrier.
Old May 9, 2013 | 10:38 AM
  #53
AdamMeh's Avatar
AdamMeh
I wish the PO of our '77 had kept the carrier and parts. He decided he didn't need it and threw it in the trash.
Old May 9, 2013 | 10:44 AM
  #54
Blame's Avatar
Blame
You could away trick or buy some poor soul set up .
Old May 9, 2013 | 11:46 AM
  #55
TWINRAY's Avatar
TWINRAY
Forgot to mention, the 40 yo spare is a 7.75 x15 - smaller than the 2.25 x 15's on the car.
Old May 9, 2013 | 11:48 AM
  #56
TWINRAY's Avatar
TWINRAY
d@mm, I couldn't get the long tub carrier bolt to fit in the slot with mine??
Old May 9, 2013 | 11:52 AM
  #57
bashcraft's Avatar
bashcraft
You can adjust the long bolts down that the lid swings on to give it more room.
To That spare tire
Old May 9, 2013 | 11:55 AM
  #58
TWINRAY's Avatar
TWINRAY
Ok, I will go at it again - well, at least after I get the center console install completed
Old May 9, 2013 | 01:20 PM
  #59
pauldana's Avatar
pauldana
Took my tire out,,,,, put springs around the bolts to hold the carrier/pan down but at the same time lets it move up if it hits something.... I keeped the pan there because I believe at high speeds, 100mph+, that a large hole there in the back makes way to much turbulence, and could also have a slight lifting effect on the rear at such speeds.
And yes, I see 100-150 mph every month...
Old May 9, 2013 | 02:28 PM
  #60
MelWff's Avatar
MelWff
Default Proper Test
To properly test this you have to let all the air out of the tire so that the sidewalls flex like a flat.
