Replace power steering pump seal
Old May 9, 2013 | 03:22 PM
cndbx's Avatar
cndbx
Default Replace power steering pump seal
Anyone able to tell me how to remove the pulley and if I can replace the seal on my pump it has sprung a leak on my 77.
Thanks in advance
Old May 9, 2013 | 04:01 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You can replace the seal; the pulley might require a puller.
Old May 9, 2013 | 04:37 PM
TimAT's Avatar
TimAT
You can replace the seal; the pulley WILL require a puller.
Fixed that for you Mike-.
Any hammering, made up puller or just about anything other than the GM recommended tooling, you'll get to replace the pulley and very possibly the pump. The pulley is easy to bend, and the vanes in the pump don't respond well to shock.
Maybe Auto parts stores have to remove/install tools in their borrow program.
Old May 10, 2013 | 04:34 AM
TurboStitchCW's Avatar
TurboStitchCW
They aren't expensive at all. Buy the pulley puller/installer, that way you have it if you ever need it again.
To Replace power steering pump seal
