two post lift
Old May 15, 2013 | 06:37 PM
Priya's Avatar
Priya
Originally Posted by 69427
Nonsense.
I have a 4 post lift. I've used it for hundreds of modifications on my car, from lifting off the body and engine removal, to lesser mods such as exhaust system changes and suspension upgrades.
I can't think of anything doable on a 2 post lift that I can't do (or haven't already done) on my 4 poster. But I can think of things that I've done that can't be replicated on a 2 post lift.
So, if you want to remove all four tires, how do you do that?
Old May 15, 2013 | 08:34 PM
toddalin's Avatar
toddalin
Nonsense.
I used the two front arms on my 2-post to yank the intake manifold off the engine. Would be interesing to see done with a 4-poster.
Old May 16, 2013 | 12:50 AM
my 76 ray's Avatar
my 76 ray
The easiest way is two bridge jacks but it can be done with jackstands.
Old May 16, 2013 | 12:52 AM
my 76 ray's Avatar
my 76 ray
Same way I removed the body. Raise the lift, support the body/manifold and lower the lift ... but why???
Old May 16, 2013 | 07:16 AM
noonie's Avatar
noonie
The 2 post lifts are much, much easier to use for almost all repairs, hense why all repair shops use them.
For storage, it would be easy to make the bridging shown in alswagg's pics out of steel channel.
Any floor reinforcement costs would outweigh all the extra dodads needed for a 4 post anyway.
If you're serious get both.
Old May 16, 2013 | 08:04 AM
alswagg's Avatar
alswagg
As for what you can and cant do on a 2 post vs 4 post. We regulary pick up 26' boats off of the trailers and then pull the trailer out from under so we can work on the bottom..... Can't on a 4 post Any way, a 4 post takes up more space than a 2 post, however if you have the room and are going to use only for a light weight car such as the vette, the post would work fine. However if you want to be more versitile and pick up larger loads, I suggest a 12,000 to 15,000 lb lift 12' wide If you have high cielings such as I do, 14' tall mast would be my minimum. I can clearly walk under our arm and plates, no worries of banging your head ever. I am 6' Good luck with your decision. Al
Old May 16, 2013 | 06:41 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
You're joking, right?
Old May 16, 2013 | 06:44 PM
69427's Avatar
69427
I lifted the body off my '69 with my 4 post lift. An intake manifold removal would be child's play( assuming I was too lazy to just reach over the fender and lift off the manifold by hand).
Old May 16, 2013 | 07:16 PM
Priya's Avatar
Priya
No.
Obviously you can remove the four tires on a four post lift the same way you'd do it on the ground, my point was how does a four post hoist compare with a two post host in terms of assisting with that job? Obviously you missed '76ray's response:
So, sometimes a two post is better than a four post.
The Punisher's Avatar
The Punisher
Old May 16, 2013 | 08:04 PM
69427's Avatar
69427
No.
No, I saw it. I just couldn't believe you were serious about asking that question.
And most times a four post is better. What's your point?
Old May 16, 2013 | 08:10 PM
toddalin's Avatar
toddalin
Not a matter of being lazy, matter of being stuck on there but good. About lifted the car off the ground.
Old May 16, 2013 | 09:32 PM
  #33
Priya's Avatar
Priya
That sometimes a two post hoist is better - can't you read?
Old May 16, 2013 | 11:16 PM
  #34
alswagg's Avatar
alswagg
I think someone wished they had a two post. Anyway, I am glad I do and have the plates for storage. The only shops i know who use a four post are the quick lube shops. Al
Old May 18, 2013 | 02:35 PM
  #35
69427's Avatar
69427
I'm actually quite a good reader (and writer). I just happen to disagree with you.
I've done just about everything imaginable to my car on my four post lift (frame swap, engine swap, trans swap, differential swap, exhaust upgrades, wheel/rotor/caliper/pad upgrades, alignments, ride height changes, suspension geometry changes, etc), and I've found the rails to be a convenient platform to use as a reference horizon, tool shelf, and a safe standing platform when alternating between under the car and under the hood.
I have no issue with you preferring a two poster. It's your money and your choice. I just believe a four poster is a superior choice, and not just for the nonsensical "primarily storage use".
