Molded in bumper problem.
I wetsanded the rear portion of the car, block sanded from 1000 to 2500 the paint job came out great with very little orange peal or junk in it.
Buffed out the rear bumper on the passenger side, and there was a line where the bumper was molded in, not a crack but I could see where the seam was. Like a ghost line. When I did the body work I blocked it and checked it 100 times. I sprayed epoxy over it and there was no sign of it. Epoxy goes on glossy so you would be able to see any ripples in the panels. If you run your hand over it it is perfectly flat. It isn´t wavy. Then on the drivers side there is a little dimple that you can see move when the bumper flexes, yes these are flex fiberglass bumpers. The top part along the spoiler is perfect. You can´t see the seem. The dimple is very small and the ghost line can only be seen if you are looking for it. I know it is because I used a flex bumper. I have molded in a few real glass ones and never had this problem. And yes I used the correct mat and resin for the panels.
This really has me pizzed off, I don´t know if I should finish buffing the back and the rest of the car and wait to do it over or just do it now. This would pretty well finish any use this summer as there was some other things I was going to do on it after the paint was rubbed out.
I can only think its going to get worse at time goes by. I think I would deal with it now and get it over with. I dont have any experience with flex bumpers, but I always thought the only way the bumpers could be blended in to the body were with the stiff fiberglass covers. Rest of the car is probably perfect. My heart goes out to ya, thats a lot of work. Wish I had the solution.
For example my present L88 hood was made without topcoat and then painted (not by me) and in certain light I can see the glassfiber weave through the paint. Annoying, got to fix it before next paintjob.
That would only happen if you used glass cloth instead of mat. I also used the same material trough out the seem and it only appears on the side. The passenger side is about 4 inches long and the drivers side is 1/4 inch long. I used epoxy to seal it. But maybe I should have used some gel coat on it.
Well anyway I will have to fix this. I also had a few people look for the problem and no one could see it until I pointed out the area.
It doesn't make sense in one way but in another it does. Expansion and contraction is what it boils down to, I guess. Black only makes it 200 times hotter. We used the body seam compound between the bumper and front clip then cut a V groove - 2 layers of glass then Duraglass before sanding and priming in hopes of avoiding this but no luck. It seems to have settled and luckily isn't any worse now but sure wish it was there.
I did the same as you did as you did. I did with all the right materials, but you are right it probably is because of the color and temperature.
I went out to look at it this morning and I really had to look to find it. My car is also black. The others I have done were red. So that must be the reason I didn´t notice it that much. I guess I will get used to it.
I would have rather used the glass ones but I didn´t intend on molding them in at first until I saw the flex bumpers didn´t fit well. Then after slicing and dicing it was the only way out.
And to be clear, did you use the "fiberglass flex bumpers" or something else?
I used Evercoat SMC resin. I don´t think that was the problem.
Yes I used the fiberglass flex bumpers. I have been doing body work for 40 years and Corvette for many of them. I am aware you can not mold stock rubber bumpers onto the car.
I thought about that. Maybe a motion type stripe. But that would be more work than just redoing the back. I would have to paint the stripe and then clear the whole car.
Polyester resins are the worst for repairs for many reasons, some of which are, not flexible, up to to 7% shrinkage, final cure up to 30 days (with shrinkage), prone to micro cracking from shrinkage, poor adhesion.
Colder climates exasperate any problems almost creating a "post cure" condition.
On the other hand epoxies have less shrinkage (one I use has ~1%), adheres to all composites, is flexible without cracking, uniform curing, etc.
Black is always difficult because it shows any flaw better.
Not knocking any experience, but the best material is always a good start.
As always there will be some that say they have been using poly since whenever, but chemistry supports epoxy for repairs.
I am no pro but have been using epoxy forever making surf boards, doing boat repairs and even minor Vette repairs etc.
I seem to believe that the resin I used was the one to use. It was recommended here. Also the supply house I use recommended it.
I also have done extensive repairs on Corvettes and always used regular fiberglass resin and never had a problem. The last 2 vettes I molded bumpers onto I used regular resin. Never had a crack. And they were both late 70´s vettes. I also don´t think the fiberglass resin would cause the problem because it is a visual problem and not stress cracks, which then I would understand the different resin. The car hasen´t even been driven yet so there was no bumping or stress on the repair. Also if I just filled the notches with bondo they would look great until I started to use the car. The other thing is I used the same stuff on the front bumper and no problem.
As for flaws, there are no flaws. The body is straight as an arrow. The lines seem to appear as the temperature rises. They are more prominent after I run the buffer over them. The problem is under the clear.
So I guess the people who use SMC resin on their panels have been using the wrong products.
So all the guys on here that have used SMC resin on their cars thinking it was the right material are wrong.
