Window Regulator
Old May 15, 2013 | 10:15 AM
czardali's Avatar
czardali
Default Window Regulator
The power window regulator gear spring broke off my regulator. Is it an easy install or is it best to get a new window regulator? Thanks in advance
Old May 15, 2013 | 11:19 AM
Roco71's Avatar
Roco71
Its not a big deal to install I know that I did both doors on my 71 while the doors were apart. I am not sure if you can do it with the regulator still in the door mine were out. The only reason I can see for replacing the whole regulator would be if the teeth on the gear are worn even at that you can rebuild it.
Old May 15, 2013 | 12:57 PM
Dega500's Avatar
Dega500
Do you mind suggesting a good place to buy the rebuild parts for these and similar items?
Old May 15, 2013 | 01:20 PM
Roco71's Avatar
Roco71
There are several good vendors that support this forum that have what you need. I hate to endorse one over the other but I use Zip a lot because they can deliver within two days of ordering from were I am located. Once you remove the regulator and inspect it you may or may not need more than just the spring.
http://www.zip-corvette.com/GroupDetails/SubGroupResults.aspx?gid={25f4e31b-696a-4964-9f42-c1c32210941e}&SearchType=_GROUP_SEARCH&G roupName=Power+Window+Regulator+%26+Repa ir&
Old May 15, 2013 | 02:02 PM
Dega500's Avatar
Dega500
Thanks,
Old May 15, 2013 | 02:48 PM
czardali's Avatar
czardali
i knew this day would come I'd had to open this door up. spring ordered. thanks again!
Old May 15, 2013 | 03:25 PM
jdp6000's Avatar
jdp6000
If the regulator is in there real nice and the window works well try to do it without taking it out. You should be able to see up in there with a mirror. Remember the spring is installed with the regulator in the full up position. The trick will be getting the arm in place. You maybe able to do this by undoing the upper stops on the track and powering the window up just a bit more. If you choose to try this make sure you mark there position and return the stops to the exact same place. If it doesn't work its no big deal you need to remove the upper stops anyway to get the regulator out.
There is a picture at this link that should give you a visual of what to expect.
http://forums.corvetteforum.com/c3-t...m-1978-c3.html
Old May 16, 2013 | 03:42 PM
czardali's Avatar
czardali
you know what i need? instructions how to take out the regulator and install it. since i dont know what i am doing, i was thinking replacing the spring with the regulator out of the door would help me. maybe im making it harder than what it actually is
To Window Regulator
