73 decode
Old May 16, 2013 | 08:48 AM
4 speed's Avatar
4 speed
Default 73 decode
here a picture of the trim tag it reads:
L07
TRIM 412 972 PAINT
click here for fullsize
http://s350.photobucket.com/user/dir...ary/73%20vette
I had started another thread but it had shifter info , wife being a smart ***, and was a few weeks old, I figured I would do one just on the trim tag
I have found glass work along the front of the floors under the carpet thanks to a busted oil line. and there is a small patch on the front of the drivers front fender.
if some replaced the front clip, would that include the tag, I can't seem the find any frame damage. and most stuff looks to be original never unassembled , or atleast together for a long time.
Old May 16, 2013 | 08:56 AM
4 speed's Avatar
4 speed
also I thought I was seeing black , red, silver paint layers. but would the black the factory gel coating and this car being an originally red car. I can only find red and silver over spray
interior parts look to be a maroon color painted tan
also are there any hidden vins to check?
Old May 16, 2013 | 09:13 AM
HBI's Avatar
HBI
Neither 972 nor 412 are 73 numbers. They are both 72.
972 is classic white
412 is blue vinyl
Old May 16, 2013 | 09:15 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by HBI
Neither 972 nor 412 are 73 numbers. They are both 72....972 is classic white...412 is blue vinyl...
Tag may not be a 73 tag or your 73 could be a 72? What is your VIN?
Old May 16, 2013 | 10:37 AM
Mike Ward's Avatar
Mike Ward
Originally Posted by 4 speed
also I thought I was seeing black , red, silver paint layers. but would the black the factory gel coating.........
The factory didn't use gel coat at all, never mind black gel coat.
Old May 16, 2013 | 11:36 AM
oldsarge's Avatar
oldsarge
Yep, looks like a 72 tag not 73 ??????
Old May 17, 2013 | 09:44 PM
Tom73's Avatar
Tom73
What are the first seven digits of the VIN?
Old May 18, 2013 | 07:08 AM
4 speed's Avatar
4 speed
1z37J3S4
if someone replaced the birdcage, what would this involve.
any pictures of this proceedure???
Old May 18, 2013 | 07:18 AM
4 speed's Avatar
4 speed
ok. after googleing 73 vette birdcage images, I think my car must of had this done, because when I had the interior out for the seat belts, the vertical panel behind the seats isn't quite flush to the hump under the e-brake console, plus the 2 rivits are still in the panel but not into the floor hump.
is this leagle?, the vin matches title , plate and engine.
can I get a 73 vin plate, is that leagle?
Old May 18, 2013 | 10:04 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
1z37J3S4
Your VIN looks correct for a 73. Have a look at his site:
http://www.73spot.com/index_stats_files/s_vin.htm
Replacing the VIN tag is not legal but replacing the trim plate ( probably) is if it bothers you. Not sure where you'd find a 73 plate to match your interior though.
Old May 18, 2013 | 10:07 AM
4 speed's Avatar
4 speed
opps! I meant trim plate!
Old May 18, 2013 | 10:32 AM
Mike Ward's Avatar
Mike Ward
There's at least one guy that sells repro trim tags. In addition to being fairly expensive they make the car smell slightly of counterfeit. Since your original tag is gone and you have no real idea what the original colour scheme was and would have to guess at the trim tag date, your repro tag would stink strongly of counterfeit.
Old May 18, 2013 | 11:07 AM
Tom73's Avatar
Tom73
May just want to pull the trim tag off and go necked
Old May 18, 2013 | 02:37 PM
GRIZ73's Avatar
GRIZ73
Default Trim tag
Www.trimtags.com. Will fix you up.
Old May 22, 2013 | 02:12 PM
4 speed's Avatar
4 speed
if my car has a 72 bird cage, would this make the rear window removeable, seem that the rear window trim doesn't fit to well, has a gap all the way around.
Old May 22, 2013 | 03:04 PM
Easy Mike's Avatar
Easy Mike
...May just want to pull the trim tag off and go necked...
I got arrested for that.
...if my car has a 72 bird cage...
Your bird cage could be 73. First part of the VIN indicates a 73. Your trim tag is apparently from a 72.
...would this make the rear window removeable...
72 rear windows are removable; 73 rears are not removable. Be aware that does not necessarily prove anything since a previous owner could have installed the 68-72 removable window in a 73.
Old Jul 6, 2013 | 04:06 PM
4 speed's Avatar
4 speed
ok. back on this trim tag stuff,
the tag had signs of red paint, like it was taped off badly.
I decided to pull the tag, the car is white under the tag, but I noticed several rivets on this upright panel. also noticed a piece of steel welded to the frame in the LR wheel well
near the turn up. thinking car was in an accident and maybe had the frame straightened and replacement of some body panels.
also found what I believe to be 2nd owner on FB. she won't answer my friend request or any thing about the vette. maybe accident was fatel to someone.
To 73 decode
