Just re-ringed my 406. it started right up and I drove it around town (approx 15 miles) and varied the load, a couple hills, etc. I didnt get on it at all. The drivers side is burning as clean as can me, but the passenger side is burning oil pretty substantially.
I've parked the car because I'm a little nervous about driving it anymore. I've read varying methods of break-in and I would like to know if anyone has any advice on what I should do now.
The engine has a roller cam and I'm breaking it in with 10/30.
Fred
Do a compression test and or a leak down test on all cylinders. If I get it right you put new rings in worn cylinders. Worn cylinders won't be round in a worn engine. I suspect the cross-hatch is long gone. Concidering this, I suspect you'll have a rough time getting the rings to properly seated.
What he said. Unless you put all the rings upside down on one side, that's the most likely explanation. Look at the plugs-are they oil fouled? Small blocks are notorious for intake leaks...
