At a Loss
Old May 18, 2013 | 10:03 PM
Bad Kharma71's Avatar
Bad Kharma71
Default At a Loss
Ok so most of you know I just bought my first 1978 Corvette. Im kinda at a loss of where to start restoring it. Mechanical, Interior then Exterior? So far the only things I can tell are wrong is the headlights wont pop up, I put a new bulb in the low beam but only certain ones come on, it needs some new interior but its not too bad, the door locks, the passenger door wont open and I have tried the inside lock but its like its jammed, then just a few other little things to get it going. But so far it drives really good. Needs a tune up. Suggestions welcome, I want to do this right.http://s1170.photobucket.com/user/Ba...?sort=3&page=1
Old May 18, 2013 | 10:34 PM
brent319's Avatar
brent319
C3 of Year Winner (appearance mods) 2019
I cant see your pictures, but I would make a list of what needs to be done for a starting point. Then pick out the things that you need to do to make it safe and reliable. Then I would drive it and enjoy it and then prioritize the rest.
Congrat's on your first corvette.
Old May 18, 2013 | 10:41 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
It doesn't seem like such a bad car. Don't be so moody!
Old May 18, 2013 | 10:58 PM
chrisNY's Avatar
chrisNY
I wouldn't try to fix everything all at once, trust me you will never run out of things to fix, cus there will always be something else to work on, figure out what you need to work right first, if it drives good and is safe, I would start with you headlights, why wont they come up, vacuum?, actuator? mech stuck or broke? new plugs and wires? you will figure out what you need first as you continue to drive it.
I cant see you pics either it says you album is private on photo bucket.
I think the first thread I looked at someone said "keep oil in it and drive it like you stole it" enjoy it, your more than halfway there cus you can actually drive it now
Old May 19, 2013 | 01:18 AM
my 76 ray's Avatar
my 76 ray
You need to make your album in photobucket "public" so we can see it.
Old May 19, 2013 | 06:33 AM
Sids04's Avatar
Sids04
This video is awesome.. It will help you with your headlight issues
Old May 19, 2013 | 07:29 AM
scottw's Avatar
scottw
Get a vacuum pump/gauge and start troubleshooting your headlights with this link.
http://www.corvette-101.com/vacuum.htm
As for where to start. My priorities, after figuring everything I wanted to do, are safety (brakes, etc.) driveability, interior, exterior.
Go through the car, figure out what you want to do, figure out your budget, start the work and enjoy. The good thing is it drives so you will be able to do projects and enjoy driving at the same time.
Old May 19, 2013 | 08:31 AM
bwinterstine's Avatar
bwinterstine
I recently bought an original but rough 75 for cheap. I started by putting the car up on jackstands and taking a real close look at everything. I'm going to start with the hard stuff: take the body off and address and frame rot. I know I have to repair the frame around the windshield. So, before you start any cosmetic or paint projects, make sure that everything underneath is solid. That's my advice.
Old May 19, 2013 | 08:45 AM
jnealg's Avatar
jnealg
Pick an issue and start working on it. I promise when you start working down your list you'll start finding plenty to work on.
My list is prioritized :
Safety issues
Mechanical preventing my driving
Mech other than above and can wait
Aesthetics like interior, trim, paint etc...
Old May 19, 2013 | 12:14 PM
Bagpype's Avatar
Bagpype
Your photos are set to private so we can't see them.
Old May 19, 2013 | 03:35 PM
Bad Kharma71
Default Pictures
Ok I got the pics set to public. The link should work now.
Bad Kharma71
Old May 19, 2013 | 03:49 PM
Priya's Avatar
Priya
I can't believe you bought that car for less than $3500 and you're whining about it.
Old May 19, 2013 | 04:01 PM
Bad Kharma71
Not whining just want to make sure I do it right restoring this. I have been through this before with my first car 1966 Mustang and it was White/Tan.. Hmmm starting to see a pattern.
Old May 19, 2013 | 04:08 PM
Priya's Avatar
Priya
Gotcha.
Old May 19, 2013 | 04:24 PM
my 76 ray's Avatar
my 76 ray
If it spent all its life in Alabama the frame ought to be relatively rust free. Looks like you might have gotten a good deal since you said it runs pretty good.
Old May 19, 2013 | 05:14 PM
chrisNY's Avatar
chrisNY
the white/doeskin combo is nice, mine was originally "frost beige" been thinking about going back to it when its time to repaint it. good luck, sweet deal. show lots of pics during the resto
To At a Loss
Old May 19, 2013 | 05:16 PM
JW3101's Avatar
JW3101
St. Jude Donor '11-'12-'13-'14-'15-'16-‘17-‘18
Safety issues
Old May 19, 2013 | 06:56 PM
Bagmup's Avatar
Bagmup
I'd keep it as a driving restoration, just do weekend projects for now. I've seen many major projects come to a grinding halt because the owner cant see the light at the end of the tunnel.
Old May 20, 2013 | 12:54 AM
20mercury's Avatar
20mercury
Default Good Advice
Good advice.
