Hard steering!?
Old May 21, 2013 | 12:17 PM
Cattiva73's Avatar
Cattiva73
Default Hard steering!?
I finally had the steering control valve, hoses and assist cylinder replaced on my '73 vette..no more leaks..however, I don't want to sound too girlish but steering now seems to be a little harder than before...I even added more power steering fluid just in case but no change.
Is this normal or there is some adjustments to be made?
Thanks for your help.
Old May 21, 2013 | 12:42 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you talked to the folks who worked on the steering?
Old May 21, 2013 | 01:11 PM
Cattiva73's Avatar
Cattiva73
Not yet...I was just wondering if this is normal.
Old May 21, 2013 | 02:26 PM
oldalaskaman's Avatar
oldalaskaman
depending on who you talk to , these steering systems are great and trouble free, or the biggest pos chevy ever made, there is an adjustment for centering the valve if its harder one direction over the other, yours sounds like your pump may need replacing also
Old May 21, 2013 | 02:54 PM
Cattiva73's Avatar
Cattiva73
The pump!..Really?!..(I think Im gonna cry )
Old May 21, 2013 | 03:16 PM
Rally68's Avatar
Rally68
Cattiva, I have the exact same problem; I rebuilt my steering valve myself, and my theory is I tightened the ball stud nut too much.
I don't know if you're familiar with the parts of the valve, but I used the pin wrench from one of my angle grinders, and it allowed me to tighten the heck out of it. There is a circular spring under there to keep the ball stud/cap assembly under tension, but that assembly needs to be able to move. I think my over-tightening took too much travel out of the ball stud assembly and is therefore limiting the piston travel in the other half of the valve, and so the fluid pressure to the assist cylinder is limited as well.
Like I said, this is my theory; maybe somebody with some more experience will chime in. I have been too busy/lazy to pull the valve off the car and try backing the nut off, but it's on my list...
Old May 21, 2013 | 03:21 PM
qwank's Avatar
qwank
I just picked up a Pump from NAPA for $45. Don't cry, it ain't THAT bad
Old May 22, 2013 | 11:29 AM
jim-81's Avatar
jim-81
I guess, in my opinion, it depends on how 'hard' it is now - relatively speaking. If it's just a little harder, it could be just from new components and a wearing in process. I had the same result. Over the past winter I rebuilt my front suspension and also replaced all steering components with rebuilt parts (cylinder, control valve, and gearbox) - not the PS pump though. And the steering was a little stiffer. Now that I have been driving it for a few weeks, it has eased up and is probably back to what it was. I would maybe give it a while to see if it eases up and go from there.
Hope this helps.
Jim
Old May 22, 2013 | 01:21 PM
oldalaskaman
Hope this helps.
Jim
excellent advise
Old May 23, 2013 | 04:36 PM
Cattiva73's Avatar
Cattiva73
Hope this helps.
Jim
Or..your arms muscles grew and can't tell anymore
BTW: Thanks I'll be driving it for a while and see.
Old May 23, 2013 | 05:07 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
a couple thoughts.
tire pressure will affect the feel.
did you get a performance caster/front end align?
there is a thread about a mod to the pump to increase pressure.
has to do with washers under the fitting for the pressure hose.
I also did my pump, control valve and piston, Also bushes and joints rebuild.
A performance align.
feels harder at low speeds.
It took a while to get the car on the road and
I did not have a recent memory of the hardness.
I do know it has always been harder than my 68 with that big steering wheel.
All said and done, I like the tight firm feel of the wheel now.
Old May 23, 2013 | 07:16 PM
Scottd's Avatar
Scottd
I also rebuilt my valve, and when I stated the car for the first time, it took me a few minutes to adjust the rod correctly. By the time I got up to the top side of the car again, I saw smoke coming out of my pump and it was bone dry. I thought Id filled it enough. Anyways, it hasnt run correctly since. Steering is very tight and doesn't seem to want to return to center. Im also thinking I fried my pump. Not a big deal, but I dread crawling under that end of the car.
Old May 24, 2013 | 12:10 AM
PeteZO6's Avatar
PeteZO6
Originally Posted by calwldlife
a couple thoughts.
Actually adding shims reduces the pump pressure which increases the steering effort. http://borgeson.com/instructions/899001 the example page is for a Mustang, but the same principle applies to GM p/s pumps.
Pete
To Hard steering!?
