1969 dipstick
Old May 30, 2013 | 07:27 AM
Jwalker63131's Avatar
Jwalker63131
8th Gear
Default 1969 dipstick
Problem. My ace mechanic lost my dipstick. I thought no problem.
Wrong. I went to Ecklers and ordered one for the 327 engine. Only to find out when I got it it sticks out about 6 inches too long.
I contacted Ecklers asking them if they had a shorter one and all 3 they sell are 24 inches long. A tech there says I must have a small oil pan.
Anyone out there can shed some lite on this?
I am thinking of cutting a hunk off the one they sent so it fits.
Old May 30, 2013 | 09:45 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Jwalker63131
...Anyone out there can shed some lite on this?...
Go back to your ace mechanic. How can someone lose a dipstick?
Old May 30, 2013 | 04:26 PM
Jwalker63131
8th Gear
Default Dipstick
Mechanic was a dealer mechanic working on the side who moved.
Got the car and discovered this a month later.
Eckerts for a 350 engine only has 24 inch dipsticks for the car. I need a 19
Old May 30, 2013 | 04:45 PM
Easy Mike's Avatar
Easy Mike
65-74 smallblocks all use the same dipstick: Chevrolet #3862730. All use the same tube into the block: #3865664.
Old May 30, 2013 | 05:11 PM
Mike Ward's Avatar
Mike Ward
Sounds like the mechanic is a dipstick himself.
If the correct OEM dipstick does not fit, the OP needs to find out why.
Old May 30, 2013 | 06:19 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Old May 30, 2013 | 06:38 PM
gbvette62's Avatar
gbvette62
No small block Corvette used a 19" long dipstick, that I'm aware of.
ALL 65-74 small block Corvettes use the same dipstick. The overall length of it is a little less than 24", and it uses a tube that is 9 1/4" long, from the flange to the end of the tube. According to the Corvette parts book, the dipstick measures 20 5/32" from the Full mark to the handle, and 20 59/64" from the Add mark to the handle.
I don't have an overall length for 58-64 dipsticks, but the parts book shows them to be 19 3/16" from the Full mark to the handle and 20" from the Add mark to the handle. 58-64 dipsticks use a tube that is 8 1/4" from the flange to the end.
There were various different dipsticks used from 75-82, but I don't know that any of them were only 19" long.
If the correct dipstick doesn't work, the OP has to figure out what dipstick tube, and oil pan he has.
All 63-79 small blocks (except 63-65 solid lifter 327's and 70-72 LT-1's, without PS), used the same basic 4 quart capacity pan. Even with the wrong pan, the sump would need to be in about the same location, and should except the Corvette dipstick.
Old May 30, 2013 | 07:20 PM
javaman's Avatar
javaman
2025 C6 of the Year Finalist - Modified
2021 C6 of the Year Finalist - Modified
A little confused here...there was no 327 in 69. Did you mean 68 or 350? Or are you saying Ecklers did not show one for the 350 so you just figured the 327 stick would work.
To 1969 dipstick
