Front end rattle
Old May 30, 2013 | 11:02 AM
The Punisher's Avatar
The Punisher
Default Front end rattle
Noticed a rattling in the front end over bumps. Watch should I look for? Thanks
Old May 30, 2013 | 11:18 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by The Punisher
...Watch should I look for?...
Better streets?
What kind of ratte?
Old May 30, 2013 | 11:44 AM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
Might need a few details like what wheels brakes etc. Any recent work?
Old May 30, 2013 | 03:27 PM
The Punisher
Better streets?
What kind of ratte?
Ha ha ha.
It sounds like metal on metal to me. No work on the car lately. I am thinking either ball joints or sway bar bushings?
Old May 30, 2013 | 03:34 PM
dochorsepower's Avatar
dochorsepower
On a C3 it can be lots of things. Crawl under and look. Also idler arm, cracked cross member welds, power steering valve, A-arm bushings (C3's eat A-arm bushings).
Old May 30, 2013 | 03:37 PM
spinadog's Avatar
spinadog
#1 thing to check is for caliper/brake shoe rattle....I get that all the time and I'm 100% rebuilt suspension, drivetrain.
Just suggesting the cheaper option!
Old May 30, 2013 | 04:16 PM
Raphiki's Avatar
Raphiki
I've had 2 wheel rattles - brake pad and top hat wheel cover.
Old May 30, 2013 | 04:22 PM
The Punisher
I will take a look , thanks for the suggestions
Old May 30, 2013 | 06:44 PM
gbvette62's Avatar
gbvette62
Shot A-arm bushings or front sway bar link/bushings, are both possible. Worn out shock absorber bushings, can cause a metal to metal rattle too.
Old May 31, 2013 | 11:54 AM
The Punisher
The a-arm bushings are shot. Thinking about replacing all the front end bushings including ball joints and cutting my springs to lower the front end
To Front end rattle
