New Calipers & Pads
Old Jun 12, 2013 | 02:15 PM
aking6341's Avatar
aking6341
4th Gear
Default New Calipers & Pads
I am having an issue after installing rebuilt calipers I purchased and new pads. The rear pads and calipers were a very tight fit over the rotor, and now the pads are rubbing pretty hard on the rear rotors. I bled the brakes and broke them in properly. I drove about 7 miles and there was a lot of smoke coming from thd rear brakes.
What could be causing the issue? Is there a way to adjust how far the pistons extend? My only guess is the master cylinder may not functioning properly or perhaps the rear rotors were already warped. Its not the emergency brakes because they were removed. I had not driven the car prior to the new brakes.
Old Jun 12, 2013 | 02:44 PM
qwank's Avatar
qwank
it's possible your rear hoses are internally collapsed causing the the rear pistons to stay extended. I would replace all 4 hoses.
also, did you replace the rotors? If you mix up the front and rear rotors, something like this could happen too.
Old Jun 12, 2013 | 03:52 PM
Gilded_Splinters's Avatar
Gilded_Splinters
There isn't any adjustment that I know of.
Try this: Remove one caliper and suspend it in the wheel well with a wire or whatever so you don't stress the flexible hose.
Fit something in between the pads that's about the same thickness as the rotor and have someone press the brake pedal. This block MUST be in between the pads or you'll shoot your pistons out of the caliper. Look for movement outward when the pedal is depressed to see if the caliper is functioning at all. All 4 pistons should move and it should grip the spacer firmly.
If so, remove the spacer block (tell your helper NOT to step on the pedal). Retract the pistons with a C clamp or something similar. Hopefully they go back in all the way. Measure the space between the retracted pads as compared to the thickness of your rotor. The space should be a bit bigger for clearance.
If the pads don't retract, I'd suspect the hoses too, but diagnose before replacing parts.
Old Jun 13, 2013 | 09:43 AM
aking6341's Avatar
aking6341
4th Gear
Thanks for the replies. I will look into the hoses.
Old Jun 13, 2013 | 10:24 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Corvette brake pads are in contact with the rotor at all times; there is always residual brake pad drag. Pads do not retract, but you should not have seen smoke.
Old Jun 13, 2013 | 11:08 AM
my 76 ray's Avatar
my 76 ray
That was my first thought.
Old Jun 13, 2013 | 11:13 AM
noonie's Avatar
noonie
Loosen the rear brake line or even the bleeders at the rear slightly and see if the rotors turn more easily.
Old Jun 13, 2013 | 11:29 AM
joewill's Avatar
joewill
also, due to the heat, your rotors are probably warped now to the point that you will have to replace them, or you will have a perpetual problem of air getting in your calipers.
Old Jun 13, 2013 | 03:53 PM
aking6341's Avatar
aking6341
4th Gear
They were not replaced and were put on how they came off.
Old Jun 13, 2013 | 04:37 PM
my 76 ray's Avatar
my 76 ray
If you loosen a bleeder and it relieves the pressure it would indicate a restriction in the lines that is preventing the fluid from being pushed back. However, it sounds like they were tight when you installed them and I suspect there was no fluid in the system at that time.
If that's the case then I would look for fitment problems with the calipers, pistons, pads and rotor. For example, is the rotor being held away from the axle flange by something? Are the brake pads able to be pushed all the way against the inner surface of the caliper or is something preventing it from being pushed back? Are the pistons in the caliper able to be pushed below the inner surface of the caliper? You may need to open a bleeder screw to check that. Are the caliper mounts bent or otherwise preventing the caliper from being installed in the correct position?
Good Luck.
To New Calipers & Pads
