Rear View Mirror
Old Jun 18, 2013 | 08:50 PM
spedaleden's Avatar
spedaleden
Originally Posted by 79CalShark
Perfect!! Please provide description, make, year, how difficult was it to install?
Pretty easy install, Car is a 81 but would work for any year. Power, ground and ignition. Temp has a sensor that mounts to front grill in bumper (clips on) and temp is very accurate. Garage door programming is homelink. Compuss is built into mirror nothing to mount. Mount for mirror is different than GM mount so you glue there mount to factory mount on windshield with locktite rearview mirror glue. Mirror is a bit bigger than factory but I love not having a garage door opener in car and will operate up to 3 garage doors. I program home garage door and storage garage door.
Thats it
Old Jun 18, 2013 | 08:56 PM
DC3's Avatar
DC3
Thats it
Brand? Part Number? Vendor?
Thanks,
DC
Old Jun 18, 2013 | 09:05 PM
TPI BOY's Avatar
TPI BOY
I wonder if it's possible to mount on a 75, anyone know
Old Jun 18, 2013 | 09:44 PM
79CalShark's Avatar
79CalShark
Thats it
Thanks, great job!! now please, brand, year, model # I want to follow your lead and do the same to my '79. My guess is that this should work on a '75 as well.
Old Jun 18, 2013 | 10:09 PM
spedaleden's Avatar
spedaleden
No problem
Old Jun 18, 2013 | 10:13 PM
spedaleden's Avatar
spedaleden
Here you go
http://www.sportsimportsltd.com/aumiwiho.html
Old Jun 18, 2013 | 11:25 PM
79CalShark's Avatar
79CalShark
Thank you!
Old Jun 19, 2013 | 01:46 AM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Thanks for the link.
Old Jun 19, 2013 | 07:59 AM
alswagg's Avatar
alswagg
Well, my mirror install sucked! The damn mount came off the windshield again. I guess I am going to the window shop today to see what they can do. Road trip leaving in the Morning. 800 miles one way for the long weekend.
Old Jun 21, 2013 | 12:26 PM
The Punisher's Avatar
The Punisher
I have had good luck in the past mounting mirrors. Did you get the install kit with the spray cleaner/primer ?
Old Dec 26, 2013 | 12:55 AM
taylor34's Avatar
taylor34
I know this is a slightly older thread, but does anyone know if this type of setup is possible on a 72 or similar car? Seems like there isn't any power available to do that on my car near the mirror like some of the newer models have. I could run wires but I'd prefer not to. Thanks
Old Dec 26, 2013 | 07:47 AM
alswagg's Avatar
alswagg
Do you not have T top light? If you do, that is where I ran power from. Al
Old Dec 26, 2013 | 09:55 AM
  #33
taylor34's Avatar
taylor34
It does not appear that I do, unless it's just burned out or hidden. When I get into my car at night there are current no lights on inside, lol.
Old Dec 26, 2013 | 10:24 AM
  #34
AirborneSilva's Avatar
AirborneSilva
If you had a T top light you would know.
Old Dec 26, 2013 | 02:04 PM
  #35
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by taylor34
...When I get into my car at night there are current no lights on inside...
That's a courtesy lights issue. Check the fuse. Check the door jamb switches. Check each courtesy lamp bulb.
If you turn the headlight **** up past the stop, do your courtesy lights come on?
Old Dec 26, 2013 | 02:47 PM
  #36
taylor34's Avatar
taylor34
I think the main problem is that they're all burned out. I would guess that 50% of the bulbs in the interior are burned out between the interior lights and dash lights. I do have a bulb kit on order so hopefully that will be remedied shortly.
Old Dec 26, 2013 | 05:12 PM
  #37
Mooser's Avatar
Mooser
You said 72 so there shouldn't be a t-top light anyway.
I'm guessing they are talking about the later (77?) c3's that had a "dome" light in the t-top center panel
I ran a set of wired up the pillar and over on mine, had to tap into the fuse panel
M
To Rear View Mirror
Old Mar 1, 2014 | 10:36 PM
  #38
Aussie67's Avatar
Aussie67
M
I know this is an old thread but I have a query on the installation for a 72 / 73. Will the mirror mount to the fixings used in these cars i.e. bracket under the header or does it need to be mounted to the windscreen as per the information given in these posts?
Old Mar 1, 2014 | 11:35 PM
  #39
Mooser's Avatar
Mooser
Sorry, mine quoted but I was only responding to the lack of a center light on the pre-77 cars. When I mentioned having to run power up it was for my GPS which was mounted just behind the mirror.
M
Old Mar 2, 2014 | 01:58 AM
  #40
thegavel's Avatar
thegavel
This is what I went with....
