solid tempered tops crack or explode???
Old Jun 17, 2013 | 08:23 PM
mystingray1's Avatar
mystingray1
Default solid tempered tops crack or explode???
if a rock flies through the air or a golf ball etc... and strikes a solid tempered top will it crack or will it explode over the passengers??? i know from personal experience that the solid tempered side windows explode, new replacement tops come in solid tempered only, tired of looking at my CRACKED laminated top
Old Jun 17, 2013 | 08:48 PM
DC3's Avatar
DC3
Not sure of the answer as I don't know how those replacement tops are constructed. But, you could always have window tint film applied to the tops. Buddy of mine had his side window broken after window tinting and the film held all the little pieces of glass captive.
DC
Old Jun 17, 2013 | 11:17 PM
chrisNY's Avatar
chrisNY
I just got replacement tops this spring, they are the mirrored laminated ones, and they will only crack not explode, I think all the replacement tops are DOT approved so they can not explode
Old Jun 17, 2013 | 11:47 PM
johnnyjaws's Avatar
johnnyjaws
I worked with temperd glass and u could hit it with a hammer and nothing would happen but if u hit the corner it would pop into a millon peices
Old Jun 18, 2013 | 12:39 AM
mystingray1
thanks, i would prefer to replace with used laminated, i know first hand that if something happens to them you still have protection above you, with tempered an errant object would ruin a road trip and possible an interior as you would have a hole above you and a car full of glass, i drive the shi.... out of my vette hence the 290k so i think about things like this, i had a tempered side window explode in my face as well, was adjusting the window with my head in the door guess i over tightened the fastener, so i know what it is like to have a car full of glass! seems to me tempered glass is tempered glass t tops or not????
Old Jun 18, 2013 | 12:44 AM
mystingray1
where did you get your laminated tops? i believe the new ones are tempered only
Old Jun 18, 2013 | 08:39 AM
chrisNY's Avatar
chrisNY
if you need the passenger side one, i have a great original one that is just sitting in my garage, my drivers was cracked. i got mine from full throttle, but they dropped shipped em, i am sure there is only a few companys that sell them to all the venders
Old Jun 18, 2013 | 11:29 AM
mystingray1
yes it is the passenger side one that i need, is it laminated and what color is the tinting as they come in a number of shades from brown, light blue to dark blue etc
Old Jun 18, 2013 | 12:17 PM
chrisNY's Avatar
chrisNY
it is laminated, mirrored, and i think its bronze or tanish tint (definatly not blue), i can send u a pic/pics if you want, and the code off of it
Old Jun 18, 2013 | 12:29 PM
mystingray1
thanks, my good top is light blue i believe or dark blue, so would be a mis match, were you able to replace with a new laminated top in your tint color?
Old Jun 18, 2013 | 12:34 PM
chrisNY's Avatar
chrisNY
my drivers side was blue, it was a replacement that one of the PO's did long before i found it. my new ones are a light tan or bronze and match my camel interior perfect. i was really impressed with the replacements i got, exact match for the car exept they dont have the original date code, right color, right top, right glass
Old Jun 18, 2013 | 12:38 PM
mystingray1
are they laminated or solid tempered?
Old Jun 18, 2013 | 12:40 PM
chrisNY's Avatar
chrisNY
laminated, $1000, plus shipping
Old Jun 18, 2013 | 12:45 PM
mystingray1
wow, new? and how long ago? i thought we could only get solid tempered any more
Old Jun 18, 2013 | 01:09 PM
mystingray1
thanks for the info guess i will have to look into full throttle, if i cant find a used laminated replacement
Old Jun 18, 2013 | 01:30 PM
chrisNY's Avatar
chrisNY
yes new, end of march, safty LOF, i am assuming the L in LOF means laminated
Old Jun 18, 2013 | 03:21 PM
mystingray1
Not sure if LOF means laminated, usually the laminated say laminated and solid tempered say solid tempered, does yours not say either?
Old Jun 18, 2013 | 03:53 PM
gbvette62's Avatar
gbvette62
LOF is the maker of the glass, Libby, Owens, Ford. It does not mean your tops are laminated. Below the LOF logo, the tops should say on them either "Laminated" or "Tempered".
Factory 78-80 tops were laminated glass. They were experiencing a lot of breakage, assembling the laminated glass tops. They switched to tempered glass for the tops in 81, in an effort to reduce the amount of breakage during assembly.
In my 35 + years in the Corvette hobby, I've seen a lot of broken factory glass tops, both laminated and tempered, and I've never seen any that "exploded".
Old Jun 18, 2013 | 04:20 PM
mystingray1
My experience with solid tempered side windows is that they do explode when hit, so if a solid tempered top was hit hard enough by an object it would not explode like a side window and the glass would still be in tact? The glass would crack like the laminated and not be in tiny cubes all over the inside of my car?
To solid tempered tops crack or explode???
