steering question
Old Jun 23, 2013 | 07:51 PM
o2bnkc's Avatar
o2bnkc
Default steering question
Hey fellows (and ladies) My friend is working on a 1980 and we're having questions about the steering. This is the problem. The power steering works fine, but when the wheel is let go, it wants to turn all the way to the left instead of centering up. In other words, when sitting still and the wheel is turned fully to the right, when letting go of the wheel, it will keep rotating all the way back left! The hoses are not on backwards because that was our first thought. They are hooked up correctly. Any ideas? Thanks.
Old Jun 23, 2013 | 07:59 PM
Mike Ward's Avatar
Mike Ward
The control valve has to be balanced. The procedure is in the shop manual.
Old Jun 23, 2013 | 08:10 PM
o2bnkc's Avatar
o2bnkc
Is there any way to see an online version of this? We don't have a shop manual.
billcarson's Avatar
billcarson
and a little past 6 min into this video.watch it and learn about how the system works.i agree with all he say's but i never use a bfh or a pickle fork,too much collateral damage.
Old Jun 23, 2013 | 08:31 PM
o2bnkc's Avatar
o2bnkc
Thanks for the great info guys! Now I'll get back to the c5 forum where we spend most of our time discussing cupholder issues.
Old Jun 24, 2013 | 06:54 AM
Jim Shea's Avatar
Jim Shea
Excellent video. I know that today, most people rely on video presentations rather than the written word. I will refer to this video with only three exceptions. Here are my comments:
1. PICKLE FORK TOOL
The pickle fork is used to break the taper connection between the control valve and the pitman arm. A pickle fork will usually cut and destroy the control valve rubber boot. If you are replacing the entire valve with a new one (such as in the video) it probably doesn't make a lot of difference. However, be aware that the pickle fork can cause damage.
2. POWER STEERING FLUID
I always recommend that you refill the system with genuine GM power steering fluid. GM #89020661 or AC Delco #89021182. It is the only fluid that is specifically formulated to operate with the Saginaw power steering pump.
3. DEAIREATION (GETTING THE AIR OUT)
After tightening all the mechanical and hydraulic connections, fill the power steering reservoir with fresh power steering fluid. Fill it to the "COLD" mark on the stick that is part of the pump reservoir cap.
Now do NOT start the engine. Instead, rotate the steering wheel full lock to full lock about 20 times. This will cause the assist cylinder to act as a pump and move power steering fluid (and any air in the system) up through the power steering pump reservoir allowing air to escape. Continue to refill the pump reservoir with fluid as large air bubbles come to the surface and the fluid level drops.
If you start your engine before eliminating most of the air in the system, air will be moved up through the pump itself where it will be whipped into a milky froth by the pumping action of the power steering pump. This will result in millions of very tiny bubbles, a fluid with milky color, a pump that makes a lot of noise, erratic power steering assist, and the fluid may expand and flow back out of the pump reservoir. It will now take a considerable amount of time to effectively eliminate those tiny bubbles and get the power steering system to act properly.
With most of the air out of the system, you can now follow the procedure in the video and balance the control valve.
Overall a well made video.
Jim
To steering question
