Edelbrock 1400 question
Where do I plug in the hose coming from the EFE actuator? Do I even still need this since the carb has an electric choke? If I don't need it anymore can I just plug them off?
Will my stock hood close with the 1400 plus the .875 quadrajet to square hole adapter? Will I need to buy a different air cleaner instead to fit it?
Any help or previous experience would be great.
Since hood clearance is tight, you may have trouble with the adapter, but I don't know the height of the 1400 vs. the Q-jet. It's possible there not enough difference to matter. If there is a problem, a low profile, drop base air cleaner may compensate. If you have a serious clearance problem, consider replacing the intake as well with either a Performer or Performer EPS (the EPS is optimized specifically for a square-bore carb and has somewhat better hp and torque numbers).
I eliminated the EGR and EFE actuator and replaced the thermostat housing since the vacuum switch on it wasn't needed anymore. Besides cleaning up the appearance of the engine bay, the car ran better.
