Caliper halves bolts
Old Jul 2, 2013 | 03:06 PM
rafalc's Avatar
rafalc
Default Caliper halves bolts
Any of the usual vendors carry the bolts and washers that hold the 2 halves together? All I see is the mounting bolts....
Old Jul 2, 2013 | 03:32 PM
Gilded_Splinters's Avatar
Gilded_Splinters
I'm not sure off hand, but if you strike out, let me know. I have a few spares that you're welcome to.
Old Jul 3, 2013 | 10:36 AM
rafalc's Avatar
rafalc
Thanks for the offer. I'll take you up on it if I can't find them anywhere else....
Old Jul 3, 2013 | 11:22 AM
Gilded_Splinters
No problem.
I think I have 4 bolts and washers, although, I'd replace the lock washers, which should be a hardware store item.
How many do you need?
If you don't want to do all the leg work, send me a PM by about 4:30 today with your address etc., and I'll send them out over the weekend.
C.
Old Jul 3, 2013 | 12:21 PM
redvetracr's Avatar
redvetracr
what lock washers? caliper half bolts don`t take lock washers...
Old Jul 3, 2013 | 12:25 PM
rafalc's Avatar
rafalc
Mine had this type
Whether thats how they came or an addition from the previous owner...I dont know
Old Jul 3, 2013 | 12:33 PM
redvetracr's Avatar
redvetracr
Originally Posted by rafalc
Mine had this type
I have taken apart a lot of calipers and have never seen or used a lock washer...fronts and rears are also different sizes.
Old Jul 3, 2013 | 04:28 PM
Gilded_Splinters
You're right red...my mistake.
I must have been thinking of the caliper to bracket bolts.
Old Jul 3, 2013 | 06:18 PM
Stroh's Avatar
Stroh
I just worked on these ths past winter, and if memory serves, I'm pretty sure they are 1 1/4 inch 7/16 20's, fine thread, grade eight. Most cities will have a bolt company that supplies hardware stores and builders or maybe a good automotive place will have them. I found mine locally. Good luck.
Old Jul 3, 2013 | 07:39 PM
redvetracr's Avatar
redvetracr
those are mounting bolts not caliper half bolts...
Old Aug 28, 2013 | 09:09 PM
rafalc's Avatar
rafalc
By the way... anyone know the torque spec for these bolts? Not the caliper mounting bolts but the caliper halves bolts.
Old Aug 28, 2013 | 09:21 PM
DonnieP73's Avatar
DonnieP73
Done mine last month.
Caliper Housing Bolts, front 130# 13/16" rear 60# 5/8"
Donnie
Old Aug 28, 2013 | 09:53 PM
rafalc's Avatar
rafalc
Donnie
Thanks! I over tightened my rears a little... went closer to 70-75
Old Aug 29, 2013 | 02:10 PM
Ibanez540r's Avatar
Ibanez540r
Call these guys. They include the bolts in their O-ring kit so they might be able to sell them to you separately.
http://www.fixvetteparts.com/
Old Aug 30, 2013 | 03:06 PM
my 76 ray's Avatar
my 76 ray
Donnie
13/16 and 5/8 are the bolt head sizes.
Old Sep 1, 2013 | 12:50 PM
cottoneg's Avatar
cottoneg
I think they were like 130 to 140 foot pounds. I had to go to a shop with a sturdy vise to hit that number.
To Caliper halves bolts
