what does this lever do?
Old Jul 7, 2013 | 04:59 PM
rustynail1's Avatar
rustynail1
1st Gear
Default what does this lever do?
Hi I recently bought a c3, so am trying to get familiar with it
Just below the ignition key on the steering column, there is a little lever
Could someone please tell me what it is for?
Old Jul 7, 2013 | 05:03 PM
razman's Avatar
razman
NEVER, under ANY circumstances, push that lever! LOL....pics? i believe that some of the later C3 cars had a lever below the ignition switch that you had to push down before you could rotate the switch to off position and remove key.....
Old Jul 7, 2013 | 05:08 PM
TW1ST3D's Avatar
TW1ST3D
Yep.....That would be the the lever that you SHOULD have to push down on to rotate the key to the "Off" position and remove the key.
Old Jul 7, 2013 | 07:46 PM
fishslayer143's Avatar
fishslayer143
never push that! good one!
Old Jul 7, 2013 | 07:50 PM
loup68's Avatar
loup68
Army
Does anyone know the reason behind that? Seems like an awfully dumb thing to have to do to remove the key. Lou.
Old Jul 7, 2013 | 07:55 PM
AdamMeh's Avatar
AdamMeh
Our '77 has the same "tab". If I'm not mistaken (and I often am), the steering wheel won't lock until the key reaches the off position - possible that the lever was meant to avoid hitting the key and locking the wheel while driving?
Adam
Old Jul 7, 2013 | 08:19 PM
billcarson's Avatar
billcarson
"hang on toots i'm about to hit the little lever".
Old Jul 7, 2013 | 09:00 PM
fishslayer143
there have been many other cars with that type feature.I ve had Fords and Chevys with it . don t know why, or why it was stopped
Old Jul 7, 2013 | 09:17 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
I think that lever locks the steering column.
Old Jul 7, 2013 | 10:39 PM
Skip Burney's Avatar
Skip Burney
Don`t EVER EVER push that lever, it opens a time warp portal to another time when gas was 32 cents a gallon and all the women went braless.
Old Jul 7, 2013 | 11:46 PM
jesse10886's Avatar
jesse10886
the lever is there incase for what ever reason the key came out or if the engine is dead and you need to steer and push to side of the road or whatever the ignition will not come back far enough to lock and you don't loose steering ability it is a safety mechanism. on the 70s old cars and trucks that had colums starting to go bad you would have someone go round a turn an wheel locked in the turn and you crashed so ford gm dodge everybody started adding the ignition safety levers they do serve a purpose not stupid
Old Jul 8, 2013 | 01:02 AM
Bangkok Dean's Avatar
Bangkok Dean
Who said is forum was not helpful
Old Jul 8, 2013 | 08:13 AM
71scgc's Avatar
71scgc
YAY!!!
Thanks Bill, Keep 'em coming!
Carter
Old Jul 8, 2013 | 08:18 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by rustynail1
...I recently bought a c3...
Order an owner's manual for it. It tells you what the key release lever does.
Old Jul 8, 2013 | 02:22 PM
rjoyal's Avatar
rjoyal
My 2001 Trans Am is a stick and has a button instead of a lever.
From what I have read, it's to make it a two-step process to lock the steering column so you are less likely to do it by accident.
On my winter Subaru wagon, you have to push the key "in" a bit as you're turning it to remove it. (it's also a manual transmission.)
Old Jul 8, 2013 | 06:24 PM
KenSny's Avatar
KenSny
Sometimes the safety features are just insane. I'm sure some Fed got involved who thought it would be it would make a big difference in safety. NUTS.
Old Jul 8, 2013 | 06:33 PM
AdamMeh's Avatar
AdamMeh
Got to thinking about this - all of my Challengers has this as well ('70, '72 and a '74). Different in appearance, but the same basic function.
To what does this lever do?
