Question about installing C4 ac fan
Old Jul 13, 2013 | 01:23 PM
MrJlr's Avatar
MrJlr
Default Question about installing C4 ac fan
Bought a fan and motor for a 96 vette...
Got the old assembly out this morning....not too difficult.
Here's my question....instead of making a spacer, can't I just in-large the second hole???
In the picture above you see the first large hole the fan goes through, then inside is a second smaller hole. The fan doesn't go all the way in because of the second smaller hole.
Cant I cut that bigger without ruining anything???!!!!!
Old Jul 13, 2013 | 02:44 PM
AdamMeh's Avatar
AdamMeh
Old Jul 13, 2013 | 03:07 PM
Shark Racer's Avatar
Shark Racer
Does the fan actually go into that inner hole? Almost seems to me like it would stop before reaching the hole - IE, that hole wasn't meant for the vortex of fan air to whip around in.
Old Jul 13, 2013 | 03:10 PM
MrJlr's Avatar
MrJlr
The old shorter fan stopped just short of the smaller hole...
The new longer fan won't go in because it bottoms out against it.....
Old Jul 13, 2013 | 03:20 PM
Shark Racer
That said, I'd space it out at the firewall and not mess with the inner hole. It probably wasn't designed to have air whipping around inside of it. In fact, that's likely where air is drawn in (from the center of the fan and out). Putting the fan inside would likely cause a reduction in air flow as you'd be creating turbulence there.
Old Jul 13, 2013 | 03:45 PM
Shark Racer
I just chucked a C4 fan I have out in the garage up in my drill and gave it the old spinny spin. My theory seems correct; the fan draws air from the center (tested by pointing the assembly at a towel hanging on a rod). Regardless of direction spun, the fan directed air radially outwards from the blades and drew air towards the drill.
Old Jul 13, 2013 | 03:50 PM
MrJlr's Avatar
MrJlr
Hmmmm...well thanks for the input....
Guess I'll just go on and make a spacer then.....
Old Jul 13, 2013 | 05:08 PM
MrJlr's Avatar
MrJlr
Once again, the little lady asked me not to use the washer and dryer as a work bench.....
Old Jul 13, 2013 | 06:39 PM
mds3013's Avatar
mds3013
Shark is correct. The wheel draws in air from the center and "slings" it outward. I would space it like has been done several times before. mike...
Old Jul 13, 2013 | 06:54 PM
MrJlr's Avatar
MrJlr
Went ahead and made a cardboard template....
I'll finish next weekend and do a detailed write up...
To Question about installing C4 ac fan
