I just bought an 81 with a new Pace Performance 350/330 with 380 ft lbs and 9.1.1 compression ratio. Are there any gas and/or oil additives that I should use to enhance performance and prolong engine life?
Thanks.
It's a mysterious ingredient contained in most motor oils that causes huge fights to break out on internet discussion boards. Many fights end in tears for one side or the other when hard facts are presented that dispel hocus-pocus myths. Thought to be indestructible and self propagating like a stubborn weed.
Similar in nature to poly suspension bushings and lead or ethanol in gasoline.
2016 C2 of Year
2015 C3 of Year Finalist
Well that gave me a good chuckle. Sounds pretty accurate to me.
Thanks.
You should contact Pace.
All the Internet Guru's will not be anywhere near you when you engine is fouled up or busted.
I after having my 71 SBC rebuilt, I have followed R&D's Race Engines instructions to the max. ( no alcohol or treatment if I do use it and ZDDP oils ? )
Pace may feel different but they will be the one you call with an issue.
Use any good top tier (name brand) fuels and oils spec'd for your year engine and be done with it, no need for any additives then.
you need to find out if you have a flat tappet cam or roller..if its flat tappet, you need a brand with zinc in the oil ,mostly during break-in.. Rotella HD is a good oil for that purpose. if its a roller, you can use what you like ..stay away from all the snake-oil additives.
Use a quality gasoline and call the guys that built the motor. The validity of either side of the oil/oil additive argument is irrelevant if you have a motor issue and try to go on warranty and they say öh, you don't have brand X" sorry.
brand X may be the same as brand Y in a lab, but if it voids the warranty: then brand X is better.
