Need help sorting heater control vacuum lines
Old Jul 20, 2013 | 06:16 PM
Crahm's Avatar
Crahm
Default Need help sorting heater control vacuum lines
Studying page J142 of the ASM, for my 69 no a/c car, I see the vacuum lines and I think I understand the purpose of some of the lines, but I seem to have an extra vacuum line.
The extra line goes through a grommet, viewed from the passenger seat, just above the heater plenum, just to the passenger side of center. Where does this line go? I can pull a vacuum on it, but it doesn't seem to affect anything. Is it going to a heater valve inside the heater box?
It isn't on page J142.
How is it to be hooked up?
Old Jul 20, 2013 | 07:26 PM
79vetter's Avatar
79vetter
What color is the vacuum line? If its tan and hard then it goes to the heater control valve on the pass. side of the engine.
Old Jul 20, 2013 | 07:35 PM
Crahm's Avatar
Crahm
Ah ha!
How funny!
It is the vacuum feed line. The grommet on the fire wall was melted and had sealed off the end of the vacuum line. There was no line hanging out on the engine side of the firewall - it looked simply like a bump on the texture.
Old Jul 20, 2013 | 07:37 PM
Crahm's Avatar
Crahm
So a non a/c car doesn't have a heater water control valve? Hot water circulates through the heater core all the time?
I see in some of my searching research that other owners have installed a control valve to keep the heat out of the car.
I'm in Dallas. Seems like a dang good idea to me.
Old Jul 20, 2013 | 08:18 PM
Crahm's Avatar
Crahm
The air valve on my car is questionable.
This the the device with a red vacuum line on the driver's side and a blue vacuum line on the passenger side. When vacuum is applied to the red side, the device moves. But I can't pull vacuum on the blue side???? Isn't there just one diaphragm thing inside this device?
I tried different vacuum line just to make sure the blue line hasn't failed.
Old Jul 20, 2013 | 09:30 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Are you talking about the vent hose for the wiper arm relay.. Upper left corner in the picture.... If so, this is just a vent hose for the valve and went no where after it came through the grommet.
Old Oct 16, 2013 | 10:06 PM
Plasticfreak's Avatar
Plasticfreak
Default I'm goin' nutz!!!
Someone please shed light on this problem I'm having...I got a 75 with a/c and want to hook up my heater control valve but cannot find the white vacumn line that plugs into it,it has to come out of the firewall..........should I take the pass. side dash off? Please help!
To Need help sorting heater control vacuum lines
