While I've been messing around with my brake issue I have inspected my body mounts and they are all cracked up as usual. Can you replace one mount at a time without removing the body from the frame?
I just replaced mine on a 1980. I just loosened all 8 of them and raised one side of the body just enough the slide the old ones out and the new ones In. And then do the other side the same way.Not that bad of a job.
I took the piece of trim that's under the door off. And placed a piece of 2X4 along the bottom of the body and raised it with Jack. It will lift the whole side of the car.
