427 heads
Old Jul 23, 2013 | 07:27 PM
Mikesfreetime's Avatar
Mikesfreetime
Default 427 heads
So I pulled my valve cover just to see what kind of condition the heads were. Which numbers are the important as far as 400 or 435? I noticed the GM3T but didnt know what number meant which head?
Well I just checked the manifold and verified its the 427 400 gm 3937795..
Old Jul 23, 2013 | 08:37 PM
MakoJoe's Avatar
MakoJoe
The GM3T casting will be the plant code from which it was casted. I did a google Search just on the GM3T code to find this answer.
Take a look at this site and it might help you out some more
I also used Google search of 427 400 gm 3937795 to find this site.
http://corvettec3.ca/casting.htm
Old Jul 23, 2013 | 08:41 PM
Mikesfreetime
That is a great site! Thanks
Old Jul 24, 2013 | 09:19 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Correct heads are 3917215 for 68 and 3931063 for 69 400hp cars. The Corvette Black Book and The NCRS 1968-82 Corvette Specifications Guide list these numbers and other original part numbers. Both books are nice to have.
The 3937795 intake manifold was used in both years.
Old Jul 24, 2013 | 10:45 AM
joewill's Avatar
joewill
under the valve cover will be a casting number and a casting date. The 400HP engine had the oval port heads and the 435 engine had the square port heads.
Old Jul 24, 2013 | 12:38 PM
gungatim's Avatar
gungatim
not to hijack, but I don't think that site is correct, it lists the L71 and L89 heads as same casting #. L71 is CI head and L89 is Alum. Shouldn't L88 and L89 have same alum. heads? or did they use the same casting number regardless of material?
To 427 heads
