Powder Coat Drive Shaft??
Old Jul 25, 2013 | 04:51 PM
tjhphoto's Avatar
tjhphoto
Default Powder Coat Drive Shaft??
Is it ok to powder coat drive shaft and half shafts. I am concerned about the 400 degree temp.
Old Jul 25, 2013 | 07:06 PM
tektrans's Avatar
tektrans
I'd be more concerned with throwing the balance off of the driveshaft than the temps.
Old Jul 25, 2013 | 07:53 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
Why would you do that???
Old Jul 25, 2013 | 09:08 PM
mikem350's Avatar
mikem350
I vote for chrome!!
Old Jul 25, 2013 | 09:47 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
no issues at all,
I've done mine,
Neal
Old Jul 25, 2013 | 11:45 PM
tjhphoto's Avatar
tjhphoto
Thanks,
I want to get rid of the rust and never have to paint it again
Old Jul 25, 2013 | 11:47 PM
Sunstroked's Avatar
Sunstroked
I had mine powder coated in pewter. Replicates the bare steel the factory left them. You'll want to remove the u joints. And make sure the grooves for the u joint lock clips do not get powdercoated. Most of the powdercoat guys know this and tape them off.
Old Jul 25, 2013 | 11:56 PM
Sunstroked's Avatar
Sunstroked
The color match was so close to bare cast iron steel, it was hard to differentiate between the bare uncoated gasket surface of the differential cover/housing and the pewter color coat.
Old Jul 26, 2013 | 07:49 AM
alswagg's Avatar
alswagg
I have items powder coated all the time. Usually aluminum but sometimes steel as well. Talk to the operator, let him know all concerns. They are usually very qualified and very responsible. I try to have my stuff coated at least twice with an additional sealer. So, actuall oven time is 3 Al
Old Jul 26, 2013 | 08:00 AM
Mikesfreetime's Avatar
Mikesfreetime
Did you powder coat the rear or just the shafts? What color did you use? Looks great!
Old Jul 26, 2013 | 10:34 AM
tjhphoto's Avatar
tjhphoto
WOW, looks great, this is what I am looking for!! Do it once and be done forever.
Old Jul 26, 2013 | 01:03 PM
hicswa's Avatar
hicswa
Just the ends are cast. The shafts should be shinny with a bluish line where the shaft was welded from the heat.
Old Jul 26, 2013 | 08:47 PM
Sunstroked's Avatar
Sunstroked
As I've mentioned in other posts, nearly everything is powdercoated. Frame, all suspension pieces, brackets, you name it, most everything on the chassis has been powdercoated. The few parts I've painted has been blasted to bare and sprayed with a 2 part epoxy paint. I'm building my car the way I want it. Not exactly how it came from the factory. They always take the cheaper way out. And quite frankly not always the best. I know a little of this as I spent the first 5 yrs out of high school working on an auto assembly line. I want my car to look as good in 20 yrs as it does now.
Old Jul 26, 2013 | 09:08 PM
Sunstroked's Avatar
Sunstroked
[QUOTE=tjhphoto;1584506844]WOW, looks great, this is what I am looking for!! Do it once and be done forever.[/QUOTE
Thank you. Yes me too.
This is what a 40yr old original CA and AZ kept chassis looked like before. I don't see any blue lines where the half shafts were welded to the yokes. Do you?
Old Jul 27, 2013 | 10:27 PM
hicswa's Avatar
hicswa
[QUOTE=Sunstroked;1584512580]
Obiously your not going to see it on a rusted part. Not trying to bust your ***** so please dont take it that way. Looks nice what you did. Just saying the tubes for the people that would like to know, were polished steel and where the tube were welded you will see the heat marks from welding. Keep up your good work and thanks for
the pewter tip because cast blast is a little to dark for parts I been doing so I will give pewter a try.
Old Jul 28, 2013 | 03:12 PM
Sunstroked's Avatar
Sunstroked
Hicswa, no offense taken. I'm aware of how the cars looked when they came off the assembly line. It all boils down to...how long will it stay that way. Maybe in a climate controlled environment, the bare steel will remain that way for 10-20 yrs. I personally live in the NV desert. It doesn't get much lower humidity than the SW desert. But my 10 yr old F150 has surface rust on the cast iron differential. No big deal. It's a hunting truck. My corvette is going to be strictly a Sunday driver and local car show entrant. We all enjoy are cars in different ways. I respect the person who does a full blown factory correct restoration. And I admire the few I've seen. The o.p. asked about powdercoating these parts. I have shown him what I have done.
Old Jul 29, 2013 | 12:19 AM
wheatpj's Avatar
wheatpj
I got a new set of half shafts from Corvette Central and spayed then with around six coats a Eastwood'd Diamond Clear. That was two years ago and they still look new. The car gets drive weekends, good weather only.
Old Jul 30, 2013 | 01:16 PM
tjhphoto's Avatar
tjhphoto
Has anyone thought of sand blasting and then Clear powder coating? seems more durable than clear paint?
Old Aug 2, 2013 | 04:55 PM
tjhphoto's Avatar
tjhphoto
ttt
To Powder Coat Drive Shaft??
