Wiper Noise
Old Jul 27, 2013 | 07:48 AM
carjack007's Avatar
carjack007
Default Wiper Noise
I just finished getting my wipers back in service and installed a new washer pump. The wiper motor motor is making a clunking noise while it's running. Is this normal?
Thanks, Bob
Old Jul 27, 2013 | 10:54 AM
MelWff's Avatar
MelWff
are the blades hitting the windshield frame? does the washer pump work and then shut off?
Old Jul 27, 2013 | 11:10 AM
TWINRAY's Avatar
TWINRAY
Thanks, Bob
Afraid not.
Old Jul 27, 2013 | 11:50 AM
carjack007's Avatar
carjack007
The blades are not hitting the windshield frame. The washer pump seems to work properly. I believe the noise is coming from the washer pump.
Old Jul 27, 2013 | 02:05 PM
carjack007's Avatar
carjack007
Correction. The washer pump starts normally when you push the button but it will not cut off by itself. You have to return the lever to off. The noise is definitely coming from the pump and I think relates to the 4 lobes on the pump.
Old Jul 29, 2013 | 03:48 PM
carjack007's Avatar
carjack007
Thanks, Bob
Problem solved. The drive pin on the motor was not properly registered to the white nylon rotor in the pump.
To Wiper Noise
