Tire size recommendation
Old Jul 28, 2013 | 12:17 PM
rehirsch8's Avatar
rehirsch8
Default Tire size recommendation
I need new tires for my 72 roadster with the rally wheels and was thinking of using BF Goodrich 255 60R15 all the way around. I currently have 235 and have no issues. Does anyone have this setup? I am concerned that 255s might rub in the front or stick out too much in the rear. Thoughts?
Thanks!
Old Jul 28, 2013 | 12:37 PM
Les's Avatar
Les
That size will be no problem in the back. You may have a bit more clearance in the front than my 69 does, but I found that even 245s lacked clearance in front. I run 255s out back and 235s in front. If you can find a tire shop that is flexible, maybe they will mount different sizes to try in front like my shop did. Then you'll know for sure before possibly buying the wrong size.
Old Jul 28, 2013 | 12:58 PM
69FASTFUN's Avatar
69FASTFUN
I have 255's on my 69 and no problems
To Tire size recommendation
