Bleeding Brakes...
Old Jul 29, 2013 | 05:34 PM
Richard Cooper's Avatar
Richard Cooper
Default Bleeding Brakes...
I removed the caliper from the drivers side rear and also removed the small piece of brake line. Do I need to bleed all the lines or just the one I removed?
Old Jul 29, 2013 | 05:44 PM
ddawson's Avatar
ddawson
All. A bubble can get trapped further up the line and can migrated to a different line.
To be safe do them all.
Old Jul 29, 2013 | 06:16 PM
Richard Cooper
Will do and thank you very much.
Old Jul 29, 2013 | 11:52 PM
my 76 ray's Avatar
my 76 ray
The front and back systems are separate. You only need to bleed both back calipers.
Old Jul 30, 2013 | 09:05 AM
78SilverCam's Avatar
78SilverCam
Could it migrate through the switch?
Old Jul 30, 2013 | 11:06 AM
my 76 ray's Avatar
my 76 ray
I've learned to never say never but it's highly unlikely. The biggest problem you may have is if you let the reservoir in the master cylinder get empty then you probably will have to remove the master cylinder to bench bleed it. Then you should bleed all calipers.
Old Jul 30, 2013 | 11:58 AM
BOSTONCAMARO's Avatar
BOSTONCAMARO
agreed, I would re-bleed all brakes...
Old Jul 30, 2013 | 03:10 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Bleed According to the service manual
left rear inner, left rear outer
right rear inner, right rear outer
left front
right front
To Bleeding Brakes...
